cosworth stage 3 engine info
Old 17-01-2011 | 09:30 AM
retro d's Avatar
retro d
Default cosworth stage 3 engine info
okay so im going to build a friends YB engine, he wants to run a stage three 360ish bhp. Just wanted to know some info, is it best to go for ARP stud and nut kit for the head, also a wrc headgasket is a must but just wanted to know what gaksets you guys run, as ive had Cometic grpA before on a stage 3 and had no troubles?.
The head has had some work done, also Bd10 cams fitted so its probably best to get some vernier pulleys then.?
Thanks Retro.
Old 17-01-2011 | 09:37 AM
rog's Avatar
rog
No ARP kit, and no WRC gasket required.
Standard head bolts and Group A gasket is what you'll need, anything else is overkill IMO.
Old 17-01-2011 | 09:46 AM
Fezman1's Avatar
Fezman1
As above. genuine std headbolts and a genuine grp a headgasket wil be spot on for this.
The verniers are a worth while mod even on std cams- to get the timing spot on.
Old 17-01-2011 | 11:31 AM
retro d's Avatar
retro d
Nice one guys thanks for the info, did think it was overkill for stud n nuts etc.
Cheers I can get that sorted now.
Old 17-01-2011 | 11:56 AM
LHD220Turbo's Avatar
LHD220Turbo
standard GENUINE head bolts
small turbo escort cosworth headgasket
siemens 55 injectors or greys (i'd personally have the siemens)
t34 turbo (choice of .48, .55 or .63)
chip to suit
Thats the most cost effective.
personally i'd ditch the cams and opt for standard
Old 17-01-2011 | 12:14 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im using a GrpA headgasket and standard head bolts with 450+bhp
I would get shot of the BD10s, either use a standard inlet cam or AB07 cam.
Steve
Old 17-01-2011 | 12:19 PM
retro d's Avatar
retro d
Steve
NIce !!! That puts my mind at rest lol, I wasn't sure about the cams, if it was my engine i wouldn't use them, cool thanks for the info guys.
Old 17-01-2011 | 12:22 PM
retro d's Avatar
retro d
Steve
well that puts my mind at rest lol, if it was my engine I wouldn't use the cams but will see how it goes anyway.
Cheers Bud.
Old 17-01-2011 | 12:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
The AB07 cam is almost as good as a BD14 but you don't need valve cutouts.
You still get a great idle even though it has 15degrees more duration than the standard inlet cam.
I forgot to mention that my block is wire rung.
Steve
big_Rad
15-09-2017 10:36 AM
JasonPD
21
20-08-2015 08:36 PM
14-08-2015 08:29 AM
Old ford
31-07-2015 07:50 AM
