co level with closed loop
hi how and what should i set the co level on a msd chip with 83lb injectors and closed loop do i disconect the lambda and set the co up with the screw as normal on the ecu ifso what should the reading be anything below 3.5% as mot or lower,cheers
yes mate i think it runs up to 1991(pretty sure) so nice and easy to get a cossie through the test
Mine is 0.97% CO, HC is 137ppm, with 200,000 miles on the engine, original bores/pistons/rings, done head though, HC shows mine has not been made lean for the test, as this would go up if that was the case, I'm on greys with t3/34 and ported head etc.
hi tabetha are you running a saph with cats for those hydro carbonlevel thats pretty low ifso how many cats does the saph run cheers mate ive been strugling to get my kit car through the iva test i didnt think id squeeze it through the hydrocarbons oh and is that at part throttle?
OAP Pete
Thanks Guys .. just wanted to check... been some time since ive had older Car [ now 3Door ] remember when some years ago it was 3.5 limit when i had 4x4xSaph... but wondered if Govenment messing with it since ? ...get us off road !. Thanks again Pete.
The mapper, dave walker wasn't doing anything special, this is on the 300bhp map, I was running around 17.5/18psi due to the near 200,000 MILES the engine had on it, I was also using Comma 20W50 MINERAL oil, as the emissions would have been higher with synthetic leaking past the tired oil rings, hence the rebuild.
I wouldn't waste my money on chips/std ecu's again if I bought another cossie, best money I ever spent on after market ecu, CL makes me laugh, I get that at the flick of a switch if I want, as well as adaptive mapping, it runs better WITHOUT CL, and is better on the fuel as well.
Opposite lock one pf has been in the car and knows how it runs 100% perfect not a glitch anywhere, and idles from cold with no working iscv, as he saw when he was in it.
