headed front screen on a 2wd saph...
Nope nothing rare and NOT optional was on Ghia (Which is all the Saph is) and of course the 2000E and XR4x4, and as an option on GL IIRC, also was on other Fords of the era I.E Escort Ghia, XR3I, S2 RST and Fiesta RST. Plenty of equipment on these to put so called "Modern cars" to shame. Just a pity Ford did not renew the patent they had on the screen.
Martin
Martin
I'm glad that ford didn't renew the patent on the heated front screen, as it makes so many other cars safer by having them.
I've sat at the side of the road sometimes when there is a sudden downpour and the windows steam up, takes me about 10 mins each time to remember that I have a heated front screen!!
Only other car i've ever seena heated screen in is an alhambra? Which is basically a Galaxy. They don't seem to have been taken on by other markers to a big degreee for some reason. Don't know why - they are awesome!
Martin
little thin wires ran up through the glass bearly able to see them unless you where looking for them with a black box about 4inch x 3 inch with the electrics inside behind the dash thats what was in the old bus
Coaches built in 1979 would likely be toughened glass and not laminated, ie single pane, so could well have had wires on it just like the rear screens.
The patent actually covered the placement of the wires on the compressed sheet between the two glass pieces that make up the laminated screen.
Most aircraft screens are not made from glass, it simply isn't strong enough, the same stuff is used as serious deep sea subs, and the record breaking visit to the bottom of the Marianas Trench, which exerted 1,100 atmospheres of pressure upon the material, or in real world terms 812 TONS per square inch, no that's not a misprint.
The material of choice is PMMA, or Poly(methyl methacrylate), in various thicknesses.
Another more common name is ACRYLIC, just a special version.
salsheikh
Alloy wheels and ICE for sale
30-07-2015 09:45 PM
