Pressing Polybushes out.
Old 18-11-2010 | 11:58 PM
  #41
Char1ie's Avatar
Char1ie
Originally Posted by Danny @ Enhanced Performance
Wider wheels and tyres,gaz golds on the rear 350lb rear springs,shim kit,a stiffer rear anti roll bar and a corner wieght set up and then it will only be a matter of your driving as it will then be a contender for the win in your championship..
cheers danny
This is what I call forum advice.
The winning car in my championship (not a contender, the WINNER) has the same spec that I am running.
Danny, what Sapph do you know running 550lb front and 350LB rear springs? I have Gaz Gold at the back already. Anti-roll bar is fine. No need for shim kit yet (I have one in the garage).
Not helpful.
Charlie
Old 19-11-2010 | 12:08 AM
  #42
Danny @ Enhanced Performance's Avatar
Not helpful.
Charlie
Dont be a knob charlie,iv had more cossies than youve had cars and i was there when your car was built by us!!!
Im not digging you im telling you how to make your car better just like iv tried doing since youve known me???
If you choose not to listen then fine,no skin of my nose mate..
Your rear shocks are gaz silver i looked earlier,when you realise im right and you make the above changes you will say thanks to me and wonder why you didnt do it sooner..
Iv ran harder rear springs than you on the road mate!!!and a stiffer rarb will do wonders as will the shim kit and everything else iv advised
cheers danny
Old 19-11-2010 | 12:16 AM
  #43
Char1ie's Avatar
Char1ie
Originally Posted by Fudgey
so how do you go about removing polys from the beam? as when i swap mine over ill reuse the polys.
i used dads 20 ton press to get em in with lol, but his company closed last year so cant use it get em out.
also, with the diff mount, do you just litterally fill it with a tube of sikaflex????
I would jack up the car, loosen the beam mount, Stick a big socket between the body and the bush, then push the beam up against the car so the socket forces the beam bush out, using a second jack. This should work.
http://cgi.ebay.co.uk/Group-Poly-Diff-Mount-Sierra-inc-Cosworth-XR4Ti-/170567693041
That's the diff mount that I use.
Charlie
Old 19-11-2010 | 12:18 AM
  #44
I would jack up the car, loosen the beam mount, Stick a big socket between the body and the bush, then push the beam up against the car so the socket forces the beam bush out, using a second jack. This should push the beam bush out.
http://cgi.ebay.co.uk/Group-Poly-Dif...-/170567693041
Charlie
FPMSL!!!!Now thats some forum advice!!!!lol
cheers danny
Old 19-11-2010 | 12:26 AM
  #45
Char1ie's Avatar
Char1ie
cheers danny
Sorry Danny, didn't realise you helped build my car.
I'm not being a knob. I don't understand what you mean by Gaz Silver. I went on the Gaz site, and I rang Warren and asked him what Gaz Silver is. What do you mean? Gaz don't do a Silver coilover.
What's the effect of running 100lb harder springs at the back on my car? Who does it? My aim is to lap like the winner in my series and he runs 550 front and 250 rear. He's .8sec quicker than me in a Cossie with the same spec.
What ARB should I use? What thickness? What will that do to the handling? What car do you know running in similar spec but with a stiffer ARB? What are the lap times?
I'll do anything to the car that I know will make it faster, so happy to listen to advice but won't try it unless I can see it works.
Charlie
Old 19-11-2010 | 12:35 AM
  #46
Charlie
The gaz silver is the std range and the golds are the better ones,they are stiffer and will make the dampning better and the springs work better and will be easier to adjust to your needs..
The arb id go for would be a escos one and this will help with roll,the harder rear springs will prvent so much squat and stop the geometry going all over the show at the rear when accelerating out of bends etc and the shim kit also aids in this..
I cant tell you of a car that runs the exact spec im telling you but i can tell you your car will be far better with these changes and will be far more planted and go where you want it too...
A car in the above spec with your power id say should lap brands indy circuit in around the 55 second bracket..hth
cheers danny
Old 19-11-2010 | 12:55 AM
  #47
Char1ie's Avatar
Char1ie
I run Gaz Golds. Like this:
Spring rates and rear ARB are fine. I understand how the geometry changes under load.
I think you've plucked the 350lb rear spring rate out of the air which is fair enough, but as I have already said I have a benchmark - my fellow competitor, Colin, who is quicker than me on 250lb springs, and is in the 55s bracket.
You are guessing at a spring rate that you think will work, but Colin is proof that 250lb springs work. This is what I mean by forum advice. You think it will work, and it might do, but I'm not ringing Gaz to buy stiffer springs based on guesswork when I can see Colin going fast on softer springs.
Charlie
01-11-2015 07:53 PM
Fudgey
17-09-2015 02:06 PM
The Enigma
12-09-2015 11:12 PM
truffleshuffle
10-09-2015 10:35 PM
fuzzy
04-09-2015 11:11 PM
