Water Leak
13-10-2010, 02:56 PM
TT T38 Power
Water Leak
I have a problem with my head, i have water leaking out of the top exhaust manifod stud on No1
Anybody any idea or is my head knackered ?
Steve
13-10-2010, 03:02 PM
sounds like the head is cracked steve
13-10-2010, 03:15 PM
TT T38 Power
Just spoke with Uncle Tony and he don't think its much of a problem.
I have been told to remove the stud and cover it with sealer and stick it back in.
The stud goes very close to the water way and can break through.
Steve
13-10-2010, 03:22 PM
that would be great steve ,i must make sure myself that i never put a stud in too far in the head
13-10-2010, 03:34 PM
TT T38 Power
Quote:
Originally Posted by
james kiely
Make sure you put them in the correct way around
I have been having trouble with the nuts coming lose so i done it up £ucking tight, knowing my luck thats whats broke it
Steve
13-10-2010, 05:00 PM
The waterways are very close but if using the correct stud, tightened up to the correct torque with the correct loctite they shouldn't move on tightening, but often will come out when undoing them.
The way to get it to stay put is not by over tightening the nut, make your own locknuts, I've never had one come loose on any car in 30+ years, inc ones used on track, only takes a minute to make as well.
If the sealant doesn't work, and I suspect it won't due to the heat around there, try some Kalimex K- Seal.
13-10-2010, 05:10 PM
whats the best loctite to use tabatha as im going to putting mine back together soon
13-10-2010, 05:17 PM
Think it's Loctite 270 (Red) for studs etc, but may be wrong so feel free to correct me!
Martin
13-10-2010, 07:14 PM
270 will do the job nicely, pricey though isn't it!!
13-10-2010, 08:47 PM
Fuck me steve iv said for ages i could smell anti freeze under your bonnet!!!
cheers danny
13-10-2010, 09:22 PM
TT T38 Power
Danny @ Enhanced Performance
cheers danny
Since the first time i came to see you.
It still runs lol
Steve
13-10-2010, 09:24 PM
cossie4i
It still runs lol
Steve
Iv seen this a few times mate and it will be fine,id try what tabs said first but the only way iv sorted it in the past is to have it welded!!
cheers danny
14-10-2010, 07:31 AM
It's amazing how far a few drops of antifreeze smell will go, especially when cossie paranoia sets in!!
01-11-2010, 05:09 PM
TT T38 Power
Took the stud out today as i was changing a few water hoses, covered it in loctite.
Going to let it go off overnight before i refill with water.
Will let you know if i have been lucky tomorrow
Steve
02-11-2010, 04:02 PM
TT T38 Power
Well it ain't leaked yet
Steve
21-12-2017, 04:48 PM
I know it’s an old thread, but did it work as I have just put mine back together and I have the same issue with number 1 exhaust stud
Mark RS
12-10-2015 06:01 AM
DAZZER
30-09-2015 08:43 PM
Fudgey
21
30-09-2015 06:19 PM
