clutch cable
clutch cable
any tips on refitting the clutch cable on a 4x4 3 door?
ive just had the engine and box out and cant seem to pull it far enough to get it over the release arm do i need to reset the clutch ratchet or owt?
i remember when i took it off it pulled quite violently out of my hand
When you lift the pedal you will need to push the adjuster quadrant towards the bulkhead with your thumb, as said this will release the tension allowing box end to be put on.
to be fair to me graham i had just manhandled the engine box and subframe in on my own with no crane was pretty tired and didnt even attempt anything in the car! i just gave one quick pull on the cable before i had to go home and thought i would ask before going back today even tho i would have sorted it anyway
muz
30-09-2015 08:29 AM
