what clutch do i get ???
Old 03-06-2010 | 04:20 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
Default what clutch do i get ???
hi im coming to that stage where my clutch is slipping and i just wondering what clutch do i need to get because i havent got a clue please help me out
i have a 2 liter dohc engine but with a type 9 gearbox bolted to it what clutch do i need 2 get?
thats all
cheers
johnandhissaffy
Old 03-06-2010 | 04:33 PM
charlie luciano's Avatar
charlie luciano
Ap fast road organic plate mate
Luciano
Old 03-06-2010 | 04:36 PM
johnandhissaffy
Luciano
ok what one tho for a dohc or pinto ???
Old 03-06-2010 | 05:54 PM
johnandhissaffy
anyone know ?
Old 03-06-2010 | 06:20 PM
Depends what power you are pushing, std clutch may be fine, certainly the std ford cossie 2wd is well up to 300bhp for example.
Old 03-06-2010 | 06:29 PM
johnandhissaffy
ohh so any clutch will fit then ???
Old 03-06-2010 | 06:31 PM
johnandhissaffy
sorry i have a 8 valve engine dohc from a sierra with a 2 liter pinto gearbox
Old 03-06-2010 | 07:36 PM
martysmartie's Avatar
martysmartie
Would think as long as the clutch plate has as many spines as the input shaft does it will be ok, unless it was changed when you swapped box?
Martin
Old 03-06-2010 | 07:37 PM
johnandhissaffy
so i gota get one with the same spines then
Old 04-06-2010 | 05:53 PM
cossie604's Avatar
cossie604
Your better off getting the info off some one whose done it before, as its not just cover bolt pcd, input shaft splines etc....you've also got the throw of the clutch arm which may be different? What clutch is in it now, any part number off that to work with?
Old 04-06-2010 | 05:56 PM
johnandhissaffy
i dont know the part number but tomorrow im taking it out and going to burton and match it up cheers anyway fella
Old 04-06-2010 | 05:59 PM
cossie604's Avatar
cossie604
Any motor factors should be fine for matching it up chap.....good luck though
Old 04-06-2010 | 06:00 PM
johnandhissaffy
one thing i coulkd ask you is what shal i get i dont really want a standard one
Old 04-06-2010 | 06:07 PM
cossie604's Avatar
cossie604
If you've not done any thing to the car and you use it as a daily driver then either standard or a fast road organic....dont go paddle clutch on a 8v twin cam mate, it just aint worth the shite driving experience
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
arkeye
Ford Focus ST
20-02-2016 02:22 PM
