Head gasket gone on stage 3. What is the best one for a 3dr?
Hi all,
I had a stage 3 done a few weeks ago at Grove Garage. Been driving the car a few days and I thoght that it is peeking on the boost but not holding boost.
I found out today head gasket has gone
What is a good head gasket for a stage 3 3dr cosworth with a standard head?
I have been looking at these on ebay
http://cgi.ebay.co.uk/COSWORTH-COMET...item3ef4f9180c
I am not sure if to go for a Group A, or multilayer and is it worth fitting ARP stud bolts the same time?
Cossie Ray
Cossie Ray
When I picked up the car after the stage 3 it was running sweet and holding boost perfectly. Then a few weeks later I noticed that it was not holding boost so called up mark and took it down today and Mark said Head Gasket it shot.
I know Mark does not like Cometic Head Gaskets
Seems ok to me, or better still look on cosworth.info you'll get all the bits there. As for BHP i wouldn't worry too much, easy +400bhp. Had my 4x4 9 years and done 30k and the gasket has never blown. Had it rebuilt recently and the gasket was fine when i took it apart, just replaced it with a 0611 which was in it before, was stg 3 running about 22-28psi.
No worries, forgot to mention, depends if you know the history, but when you've got the head off I'd replace the cambelt and tensioner at the same time, or even get someone to change the valve stem seals in the head since it's off. Up to you though, just maybe save you doing it later or if it's already been done then no worries.
If the heads done 70,000 the guides will be shagged, they wear terribly on these, so budget for 16 guides, plus any valves that need doing.
There are plenty of 500+ engines running the Yb 0611 gasket, the cometic inlet gaskets are ace, the best steel HG is the single layer REINZ, the one mountune supply(they don't make it) is also very good, but personally would never use a metal gasket.
I use ARP stud and nut kit, but the lengths do need checking for bottoming when installing otherwise if they bottom in the hole before htting the stud shoulder they will lift the threads in the block, if installed correctly they will be fine, I torque my head to 120lbft, leave a minimum of 4 hours and retorque, as head gasket will compress and torque will lossen slightly.
One reason why the yb 0611 is better is due to it's fibrous nature, in that it deals with imperfections in the surfaces vastly better than a metal gasket ever would.
Cossiemodo
My multi-layer one has now been "used" 3 times so far and still holding out on my Stage 3 Cossie, so the extra initial expense has more than paid for itself vs using 3x GpA ones.
Just seems like a lot of trouble to go to in terms of getting the car all back together when you risk the gasket being on its last use.
Ye, I know Mark and Ahmed are like that
I told him that I wanted to get a few things done and told him that a few people on PF recommended it and he said that is a shit idea and they dont know anything.
When he did the stage 3 I mentioned to him to do the head gasket one time, But he said it dont need it.
Then they don't know what there talking about, do you know for certain your fans actually work otherwise you will be looking at multiple HG replacements. The circuit was sub standard to start with and can not cope with the high current draw demand of the fans, the issue is made worse now from old degraded wiring not to mention having a massive temp span. Nearly all suffered melted fuses, relays etc. The fuel pump has the same scenario as above and if you don't rewire you want a voltage check at the minimum with it under load.
Martin
Martin
Some 3 doors had warranty work which was a fan rewire, as were HG replacement(which is where the group a came from!!).
Even under development there were cooling issues esp during NVH testing.
I have never met the man, and can only go on what I see written here, but seriously if ANY tuner ever said that, on any uprated install I would go elsewhere.
When I'm on the rollers there is a pressure gauge plumbed in by the RR operator, Dave Walker, to make sure things saty as they are, lean off can be seen in emissions though.
Mark is one of the most knowledgable Ford people out there.
Charlie
I am a very easy going person when I meet someone for the first time.
I bought a cosworth about 6 months ago and I am very new to the seen and my knowledge is very limited and I admit to this. I joined passionford to learn!!!
I have asked many questions on here to learn and understand, And I have got some great responces from members on here and I ran a few things to Mark and all he said is that it does not need to be done
Say as you see I say, I wasn't put on earth to make freinds, you have the OFF button charlie.
