Help escort small turbo inlet and throttle body on to 2wd saph?
Old 15-01-2010 | 11:25 PM
G 74F 00's Avatar
G 74F 00
Default Help escort small turbo inlet and throttle body on to 2wd saph?
Hi i have just bought a small turbo escort inlet and throttle body and was woundering if you guys know the best ways to get the 4x4 saph tps to fit on to the escort throttle body? And what do you do with the iacv i have heard of blanking it off on the throttle body and using a remote fitting with the original iacv? Is there anyway of using the escort iacv?
Thanks paul.
Old 16-01-2010 | 11:16 AM
Piccies would help with the tps fitting problem.
Old 16-01-2010 | 03:42 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Thanks paul.
I was looking at doing this a while ago, I can't remember the problem exactly.
I think it was the shaft is shorter and a different shape.
You can remove the mounting plate off a webber throttlebody to swap over but the shaft is too short to reach the TPS when you try and mount the plate to the eec4 throttlebody If I remember right
In the end I ported the webber TB drilled the holes out ground the corner off the TPS and a little bit off the manifold fitted that instead. I thought it was too much agro messing about with the TPS then running a remote ISCV. You willl also have to change the TB hose aswell.
nick8saff
16-08-2015 06:35 PM
M K
12-08-2015 07:57 PM
ray barker
07-08-2015 10:00 AM
adriansaleem
01-08-2015 10:28 PM
