bit of a rush!!engine problem.!
hey does anybody no will my 1.8td sierra gearbox fit a 1.8td mondeo engine cus i blow the engine in my std an need one fast to get to work an to see me son.thanks!
better way to put it would have been "will my mondeo td motor fit in my sierra"
i think the block is different for the engine mounts so won't fit but not 100%
Ford normally have a good commonality fitting wise on engines gearboxes, so mix and match may be on the cards.
I would ask a gearbox place, bound to know for certain, I'm not even certain what engine a 2000 mondy has diesel wise!!
If the bell housing patern is the same then i can't see why not, the engine and gearbox is the easy part it's the management that will be the hard part and being a 2000 Mondeo it will be TDCI I suspect.
Martin
Martin
rite rite i see im not sire if it is the tdci or not il need to ask.but if it is do use think id prob need to change loom and everything if i go dat way?
If I have correctly understand you want to fit an Mondeo 1.8 td i a sierra td
You can fit it but you must change all accessories, sump, pick-up pipe, oil pump, water pump...
Just keep the cylinder block and the head
I have already do that
kosienutter
31
22-08-2015 09:55 AM
