Im in need of a new lambda sensor as the wires have come away right at the base of the sensor and therefore i have no way of repairing it. i run a closed loop msd chip setup on my 4x4 saph. i need to know about the cosworth lambda sensor, is it a narrow band/wide band? the wire colours on the sensor that i removed are black/white/red
Is this sensor the lamda sensor? I found this connector in the turbo side inner wing. There were three wires in it; black, brown, and white/brown. The car is -91 4x4 with redtop YBJ engine...
