is that the same turbo?how much power can i get from a t34.63 housing with:
3bar map
dark green 803
big intercooler
2.5inch exhaust without cat
on a 1991 saph 4x4?
with how many power do i need a oil breather?
thanks
3bar map
dark green 803
big intercooler
on a 1991 saph 4x4?
thanks
3bar map
dark green 803
big intercooler
on a 1991 saph 4x4?
thanks
Stage 1 i had a Breather fitted, opened my Airbox and there were bits of oil in the corner of it..
3bar map
dark green 803
big intercooler
on a 1991 saph 4x4?
thanks
your injectors & 4x4 cooler is the limiting factor in your spec.
if you changed the injectors for siemens 55lbs or greys and change the intercooler for a rs500 type you'd see near 400hp with that turbo
but obviously you will need a new chip if you were to do that
and yes oil breather is recommended, i;d change it even if it wasnt tuned!
with current spec, 340-350hp is about right, but as said, transmission is the weak point beyond 350hp/350 torque
what do i need to for the near 400hp?what headgasket?and what else please.
i think i stay with those things and chage maybe 2011 to the greys injectros.
what dit you guys made on your transmisions abd how much do that cost?
400 bhp it starting to get mega expensive with transmission/brakes your prob looking at 10k!you might as well go for 450 if you going for 400 in a 4x4 cossie!you will also need grp A fuel pump,maybe a multi layer head gasket,although a group A one will prob do!T34 is no longer any good for 450 need a t38,t4 or a gt30!also black seimen injectors and prob a spacer on your inlet plenum
dont go too much above 350 as your transmission wont be too happy!even at 350 i would not launch her off the lights
pah! its all lie's, lie's i tell ya!
Its bringing them onto boost in 3rd gear thats the main killer so im told!
Mine craves 6k launches!
*toodles off to blow his box to bits now he's jinxed himself*
i feel ashamed and the need to try harder!
I'm sure mine should of died by now, i usually destroy gearbox's in everything, cossies the only one to last a few years on me.
Maybe its secretly got a bara in!
i must have a very good box i think!
Its done lots of launches at pod (1.7 60fts, so definatly not gentle!) and loads on the road, i am really shocked by how well its lasting, maybe when its been up to you boys again in april it wont last quite so long.
