Oppliger semi cut & straight cut gearkits
Oppliger Motorsport big tooth gearkit
Hi,about my gearboxes and gearkits....we built this kit in north italy with very good materials.the are actually 3 options.
1. straight cut,new shafts,modified syncro on CNC machine for fast gear change.1st gear its a little longer than standard, 2nd 3rd 4th are shorter and 5th a little longer 168miles at 7000rpm
2.semi-straight helical gears (less Noise),new shafts,modified syncro on CNC machine for fast gear change.1st gear its a little longer than standard, 2nd 3rd 4th are shorter and 5th a little longer 168miles at 7000rpm
3.straight cut,new shafts,modified syncro on CNC machine for fast gear change.all 5 gears are shorter than standard,in this gearbox we use an alloy spacer between gearbox case and transferbox.Ideal for track days and rally.
all gearkit can handle between 500hp 550nm and 600hp 700nm
we offer the full rebuild gearboxes plus fitting gearkit (like new case,new seals,new bearings and fitting gearkit)
Customers send us standard MT75 gearboxes in any conditions and than we return it back in new conditions.
cheers
Oppliger Romain
cheers
Oppliger Romain
Oppliger gearkit
Hello,
the ratios are:
140mph aprox speed
direct top 1:1
1: 2.733
2: 1.769
3: 1.312
4: 1.041
5: 0.850
160mph aprox speed
direct top 1:1
1: 2.733
2: 1.750
3: 1.200
4: standard direct on shaft
5: 0.720
please reply and write me at: oppliger.cosworth@tiscali.it
best regards
Oppliger
the ratios are:
140mph aprox speed
direct top 1:1
1: 2.733
2: 1.769
3: 1.312
4: 1.041
5: 0.850
160mph aprox speed
direct top 1:1
1: 2.733
2: 1.750
3: 1.200
5: 0.720
best regards
Oppliger
Oppliger engine & gearbox
first road test of our powerful Cosworth car....1.6 bar of boost....we have to finish the map for 2.2bar...
engine spec:Nikasil liners on 200 block,10 long studs,Arrow cranckshafts,Arrow rods,forged pistons,ported head,double valve springs,Nimonic valves,solid followers,wild camshafts,wrc 8 injectors manifold,swedish plenum,70mm body,tubolar exhaust manifold,gt35 turbo,external wastegate,coil pack,pectel super 8,twin 044 fuel pumps,etc....ops....Oppliger BIG TOOTH GEARKIT
videos:
http://www.youtube.com/watch?v=wlwjhSHrJiA&feature=response_watch
http://www.youtube.com/watch?v=HZwbfVGnaw4&feature=response_watch
videos:
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
