Bucket seat with side mounts fixing in Sierra
Hello!
I have OMP bucket seat with side mounts and brackets already installed.
What subframe can you advise to fix this seat to original fixing points at sierra's flor?
![](http://cosysop.users.photofile.ru/photo/cosysop/1135767/large/113812892.jpg)
![](http://cosysop.users.photofile.ru/photo/cosysop/1135767/large/113812898.jpg)
![](http://cosysop.users.photofile.ru/photo/cosysop/1135767/large/113812905.jpg)
![](http://cosysop.users.photofile.ru/photo/cosysop/1135767/large/113812910.jpg)
Thanks.
Dmitry.
Thanks.
Dmitry.
Take an original Ford Sierra seat base and chop it up as follows:
![](http://i32.photobucket.com/albums/d37/charliemoseley/IMG_3627.jpg)
Turn it upside down and drill out the eight dimples underneath each sliding rail
![](http://i32.photobucket.com/albums/d37/charliemoseley/IMG_3626.jpg)
Then you should be able to remove the sliding rails:
![](http://i32.photobucket.com/albums/d37/charliemoseley/IMG_3628.jpg)
Then you can put the seat mount and the sliding rails together and fix them:
![](http://i32.photobucket.com/albums/d37/charliemoseley/IMG_3635.jpg)
![](http://i32.photobucket.com/albums/d37/charliemoseley/IMG_3637.jpg)
My pics don't have the fixings done but drill and bolt the rail to the seat mount. This will give you a race seat mount that bolts to the original floor mounts.
Charlie
Charlie
Puller of the Wrench
I fir some side mount sparcos and not matter what way I put the mounts the standard sierra rails were too narrow. Yes, I fit very wide seats for my cyclist legs..
I ended up welding some 2 inch plate along the rails in the same spot and the seat fixing points and drilled to suit. It was a bit fussy as I wanted to keep the seat as low as possible. I lost about an inch of forward movement and that's fine. My seat now hits the front of the tunnel, no problem.
Get the driving position perfect or you will hate the seats.
borboyous
22-08-2015 11:17 AM
saph in dorset
14-08-2015 10:10 AM
track.focus'd
12-08-2015 05:53 PM
