044 fuel pump priming,how long?
hi,my fuel pump seems to take a while to prime,even after a run,seems to be 20 to 30 seconds?this normal?havent seen a change in afr so must be getting enough fuel?pump only about a year old?no leaks that ive noticed,
thanks again
thanks again
My prime on the L6 ecu was about 4 seconds from memory, defo nowhere near 20-30, but it's ecu controlled, wouldn't worry so long s it's working as it is purely just a timed pulse from ecu.
Plenty of cossie paranoia, I was like it to start with, just resigned myself now to if it goes wrong it goes wrong, but it only had a hiccup or two in 3 years, even managed to do 20 miles home after HG blew, stopping every 5 miles and refilling with water.
there mite be air getting in the system check the connections on the fuel filter check the rubbers haven't crumpled up or bin pinched and then if that dnt work check the fuels pump connections (wires) c if u got a good connection
If air was getting in, or even if the outlet pipe was disconnected it would not alter the prime, the ecu does not know what pressure is in the fuel rail, it purely gives out a timed supply when it wants.
CabrioTurbo
01-08-2015 11:04 AM
