My brakes are doing my head in Help please.
Anyting forsale let me no
I have this strange problem with my 2wd cosworth.
When you start the car the Abs light goes out as normal but the pedal goes rock hard when pressed then seconds later the Abs light comes back on and the pedal is fine.
Please any one with any ideas please help.
SIERRA RS 4X4 COSWORTH
Does the red warning light come on to tell u that u have low pressure in the system ? check the relays , mine had this while driving and was the distrubtion block failure !
This could show up a faulty relay as i have removed the 4 pin purple relay and the abs light comes on as well ,[ 4 pin purple / 5 pin purple / 4 or 5 pin green will have to remove this one to check- under dash passanger footwell] abs and low pressure warning light come on after 4/5 hard presses on the break pedal as this relay has been removed . I am awaiting a new abs loom from Carlooms mine is not any use since we pluged in a snap on fault code reader and fried it
The Enigma
12-09-2015 10:12 PM
