400hp from a t34.63?
#82
Im kinda new also mate, it seems you would be best off weith a bd10 iirc? and i can imagine the .48 will come in with a kick, but will be progressive and come in earlier in the rev range.
iI personally like lag lag lag then when it comes in with a bang it makes the rears loose traction
I'd say that for the peeps 'wanting' ( ) the lag they would probably prefer the .63... but although it may 'feel' harder it prob wouldn't be as quick and spritely on the road.
Yeah i seem to recall that only Turbo Technics do the .55 housing... they start using the .63 on their T38 claiming it's unnecessary on a T34/35...
#85
I'm still confused here as to how the hell people are getting this power from the .48 or even .63 - how long will the turbo last pushing that much power through it as my old spec T34 .48, 803's was nowhere near 400 more like 330.
If people are pushing 32psi through a T34.63 how much can i run through my SCS T38.63?? which is currently at 32psi
#87
Chris, my T38 on my old Saff after Karl had mapped it was peaking @ 36psi holding around 30, made 456bhp, it was FOOKING ballistic mate.
I also agree, some of these numbers on here are very high, i,m sure Turbo life can,t be long lasting..Lol..
My T34.48 Made 363bhp with similar torque again after NMS Map, that was on Greys and peaking @ 32psi holding 28psi...Turbo has just given up on the car, i put it on brand new so it,s had around 2 and half years at this boost...
#88
Stu runs t38,s at 28 psi holding and peaks at 32 thats it,better biting the bulit and buying a t4/gt30 as 38,s drive shite in my experience t34/63 drives so much nicer ,my mates produces 28 psi at 3k reves with a t34 were my t38 is almost 5k before it is producing that much boost
cheeRS stu
cheeRS stu
#89
Stu,
I agree mate, my T38 car wasn,t nice to drive at all, laggy as a MO-FO ,came in around 4.4k or so, ok it was with a bang and pulled like a BIATCHHHHHH, but i much prefered my T34 Car tbh...
GT30 on my Evo was a nice Turbo, i,d either go for one of these again, or a RB T4......
#90
B1mbo
cheeRS stu
cheeRS stu
thats engine spec making your t38 so bad, our engine have 30psi well before 4k, about 3700ish, although on the dyno we go up in 500rpm, so 3500,4000 ect, so deffo 30psi at 4k
#91
Jimbo how come exact same spec is spot on with a t34 with same size exhaust housing ? nobody can give me a straight answer,have lots of diffrent answers,and lots of ppl have same experience with t38
cheeRS stu
cheeRS stu
#94
I just rebuilt engine, but on old spec:
T04E compressor with a stage 3 .63 exhaust & 360 degree thrust for longevity.
standard head & cams
10mm plenum spacer
Greys
500 cooler
live mapped
370bhp on the dyno peaking around 24psi. First gear was a waste of time. Needed rudimentary traction control in the form of not giving it full flip flop application. It would break traction when boost came on in second gear in the dry in a straight line.
When drag racing, would get a squeak from the wheels when changing into fourth.
I'm only running lattices with 205/15's though.
Boost came on hard around 3700revs. GREAT feeling. It was laggy but the effortless power was worth it.
Am sure with a rebuilt engine and ported and flowed head, I will make 400 at the wheels on whatever boost it takes. Hopefully around 25psi.
10mm plenum spacer
Greys
500 cooler
live mapped
#95
Depends on engine spec, standard engine with 500 cooler, good exhaust and filter, -31 actuator, fuel pump running at the correct volts, stage 3 set up on dark greens about 22psi about 340 350 or stage 3 on greys 26 psi about 360 370. but everyone will have their own views but realistic figures. Tired engine can be down 10 20 horse, or if your have cams and head work etc will achieve more as well as having more boost, but don't really want to run the turbo near max it won't last long.
#97
Greens and 023 pump = 🚑🚑🚑
Need an 044 pump
To add to above thread I have a .48 housing and boost is fully available at 3k,on the motorway at 2900 the turbo is straining to produce boost chirping like a fcukin flock of pigeons tryin to get out.
Brilliant spec eng
Harvey's green spec
T34/.48
Greens
Wrc head gasket
Std cams
Long studded
044
No head work I believe
378/375 afair
Can't praise the eng enough and on std ign
Need an 044 pump
Brilliant spec eng
Harvey's green spec
T34/.48
Greens
Wrc head gasket
Std cams
Long studded
044
378/375 afair
#102
300+
It runs anti lag mate... Yea mapped by Stu and James... Very nice to drive round town but once you push the loud pedal get ready... It's a fucking mental animal...well worth it..!
#107
Hardly worth Chang inj for 2 hp is it jimbo, I think I have a genuine 378 or summit according to your dyno printout
What's needed on my eng spec for 400 bar changing turbo and losing response ,low comp already iirc
#112
I've a t34/.63, BD14 inlet, low comp pocketed pistons and mine has been setup to peak at 32psi and it drops to around 25/26psi at the limiter (7200rpm)
No idea what power it is and frankly I'm not too fussed. Very happy with the live map MSD did and would reccommend them to anyone considering having it done!
