Who sells solid lifters for Cosworth heads?
The adjustment is by means of the shim that lives at the top, the top has a ridge around the top that holds a shim on top, these shims come in different thicknesses so the gap can be set to whatever you want.
With shim adjustment they'll probably only need doing every 30/40,000, and even then you can do swappsies, but any new ones you may need are only Ł3 each roughly.
matman
09-09-2015 05:45 PM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
