Amal valve
28-07-2009, 03:33 PM
Amal valve
What would stop the valve from clicking mine wont click now it has a new engine in
was fine before
But was a on a T3 now on a T34
28-07-2009, 05:09 PM
swindon rsoc
have you changed the chip?
28-07-2009, 05:13 PM
28-07-2009, 05:14 PM
Not yet mate also my iscv aint working at all was sweet before
28-07-2009, 05:20 PM
swindon rsoc
have you changed anything since it was last working?
Passion for Fords!
amal valve and iscv share the same feed, so its a wiring issue pal,
i think they run from the fuel pump relay area
28-07-2009, 05:24 PM
Ah that sounds good any idea what colour wires it is or is it just a trace prob
Rob nothing was changed mate
Do they have a fuse or anything
28-07-2009, 05:30 PM
swindon rsoc
sound like a wiring fault, and no i dont think there is a fuse its fed straight from the ecu... check the ecu plug etc etc....
you seem to be having way more than anough problems with that car mate lol
28-07-2009, 05:34 PM
I know
Im going out to have a look now
Back in a bit
What pin in the ecu is the feed or what colour is it
28-07-2009, 05:35 PM
Passion for Fords!
the ecu provides the earth control, both amal and iscv have an ign live, run a continuity check and probe it out
28-07-2009, 06:19 PM
I just Fucked it now had no power to either put a lie on the amal but touched the other wire tiny spark now no spark no pump nothing
28-07-2009, 06:21 PM
Passion for Fords!
you probably spiked the ecu if you sent 12v down the earth wire.
continuity check doesnt involve sending power anywhere
28-07-2009, 06:24 PM
swindon rsoc
Great what I NEED A NEW ECU THEN
28-07-2009, 06:27 PM
28-07-2009, 06:28 PM
Passion for Fords!
well, erm, it will need testing now to see if you fried it
28-07-2009, 06:30 PM
Who can test it or is it a case of fit it in another car
28-07-2009, 06:31 PM
The fuel pump fuse has blown I fitted a new 1 and nothing would it of mashed the relay aswell
Passion for Fords!
msd can test them,
you could do a visual check of the board to see if its crispy
28-07-2009, 06:34 PM
The board and all look sweet and smell normal
28-07-2009, 06:37 PM
Found a dry joint in the ecu
Passion for Fords!
well, my next step would be get the ecu tested then get a wiring diagram and pin out to check the ecu feeds and relay feeds,
but if your not confident get someone to help you
28-07-2009, 06:39 PM
Cant I just set fire to the car and claim the ins
28-07-2009, 06:44 PM
Its pin 19 thats dry any1 know what it is
28-07-2009, 07:19 PM
Right I have resoldered it and it starts again the amal clicks after a second or 2 when
running but no ISCV
How do you test it the ISCV Can i just wire it direct to a battery and listen for a noise?
28-07-2009, 08:03 PM
3-door moonstone
amal
Just had mine setup at noble motorsport there was a burnt out electrode in my ECU which stopped the amal valve working, they managed to fix it top blokes.
29-07-2009, 11:07 AM
The amal works now but the i think my iscv is seized
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
rs_jim
19-09-2015 08:41 PM
