Saff 4x4 coolant bubbling
Old 13-05-2009, 06:15 AM
RSRoy
RSRoy's Avatar
Default Saff 4x4 coolant bubbling
My brothers Saff 4x4 has a weird issue with his coolant. When he drives the temps of the water are normal, not too high or too low. The system doesn't leak or whatever but after he drove a while and turns of the car the coolant in the reservoir stats to bubble.
How does the air get into the system if it isn't leaking?
It's a bit difficult to explain as I'm not Brittish
Old 13-05-2009, 06:40 AM
This is normal, when you turn off the engine when hot, the water still absorbs the heat from the engine, as it is not being circulated through the radiator it continues to get hotter and hotter, this will form air bubbles, and hot spots of water in the system, it's merely this finding it's way into the expansion tank, whereupon it meets cooler water, and air space and so the air comes out of the water, it couldn't before as there was no free space, as water is much denser than air.
Whenever water is spun it causes air bubbles as well, this is why ship propellers erode, due to cavitation caused by spinning propellors, it causes pitting of the blades.
Old 13-05-2009, 08:22 AM
RSRoy
RSRoy's Avatar
I haven't noticed it at my 3door but if it's normal then we'll just leave it I guess
Thanks for the awnser.
Old 13-05-2009, 02:46 PM
Gazzonator
Gary Krishna
Gazzonator's Avatar
My 4x4 does the same and has never given me any trouble (now touching a large piece of wood!!! ).
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
Iain Mac
30-09-2015 09:39 PM
cossie330
27-09-2015 04:13 PM
ajamesc
27-09-2015 02:25 PM
Quick Reply: Saff 4x4 coolant bubbling
