standard exhaust cam & bd 10 inlet
does anyone have any experience of the above?
i have been thinking of giving it a try!
my spec is suitable for 400 bhp.
many thanks
n.b. please keep comments related to cams and i know people will say keep the standard cams but surely there should be a difference if the bd 10 inlet pumps in more fuel.
many thanks
DANISH cosworth abuser
Hi m8.
Ive done a friends escos bt with a bd-12 inlet and 2wd exh manifold, and it is a super upset for a std engine.
Pulls like a std car but where the std tails off @ 5500rpm, this goes almost to the limiter before it tails off.
Wh havent got it rr yet, but wery close now.
Can only recomend it tho
i have that set up on my 3door now with ported head and port matched inlet on greens and standard t3 and 4x4 intercooler it made 337hp/330lb/ft and is lag free and very quick low down, i reccommend this set up as is a real fun to drive
T34 rs500 intercooler and standard cams. i made 335bhp and 363lbft which is awesome set up and pulls really well.
IMAO i would speak to a tuner and ask for there info as they would have seen more results on rollers with different setups and will know the answer
hope this helps
You also have a standard turbo and a tiny intercooler ie nothing like a 400bhp spec which mrintex says he has. If he's got a 400bhp spec engine then it must be running at least a T34 and a 500 style intercooler, which will react totaly different to your spec due to having a slower spooling turbo and a greater volume to fill.
please can people now simplify things and say whether they would put a standard bd8 cam or upgrade either to a bd10 or bd12 inlet cam. bearing in mind, the exhaust cam will stay standard.
many thanks for everybody's time and effort!
i run bd10 inlet,std ex,t34.48 388hp,375lbft with i real nice power curve it climbs all the way to the limiter but still got good mid and low due to the .48!
this was all verified on harveys dyno before anyone starts...
Hi, I design and manufacture cams for ford engines. I must ask, what do you want to use the car for?
I have a set of BD14 inlet BD10 Exhausts for sale (much below retail price) which i was going to put in an engine but have not had time.. If you are keeping the car on road, this pretty much the limit for road legal vehicles. they are brand new.
If you still want advice, feel free to contact me.
So, cam wise, depends what you want to use the car for!
I'm getting 400bhp with standard cams with 386lb/ft thats with a t34.63 and greys. once the turbo's on song it pulls right upto 8000rpm, it is a low comp with all the usuall work done.
Can believe it a friend of mine made 391 hp on a t34-48 on the rollers the operator said it was one of the higest he has seen on a cosworth
Danielbetty
03-10-2015 06:01 PM
