failed mot today,welding needed
hi,cossie failed mot today on the chassis part between rear spring and rear beam mounting point,do i just patch it up or get new chassis legs from hadrian car panels,do these fit over old ones?also i see they do rear outriggers what are they?is it them i would need or the chassis legs?im assuming rear beam,petrol tank etc all to come of to do job?any suggestions much appreciated,thanks col93saphcos
very common and serious place for saphs to rot
thats what wrote off my old saph a few years back
chech the chassis legs in front of the springs as well as they
usualy crack there as well if they're rotten at the back like yours
its up to yourself if you just want it patched or fully cut out and replaced
either way it needs the full rear beam removed anyhow,
and a quick patch up will get it thru the mot
or a new chassis leg will cost a whole heap more tp sort out
you get what you pay for kinda thing mate
sorry to here about it, as i said, it wrote my car off as i didn't want it
welded that much, i thought it better to reshell
obviously your car so your decision
was going to see if could hire a mig welder,not sure if can manage it but was willing to try,garage i use would not be able to do it for about a month,their well busy,wouldnt be so bad but got bloody 6 degree beam coming soon!thanks col93saphcos
ye not sure when getting beam,its the passenger side thats got a hole kind of when you look through the trailing arm between spring and beam mount,think outside of it ok,drivers side looks rusted so would do that as well,you reckon plates?or new leg things?thanks col93saphcos
no,mot ran out on saturday,have had it booked in for near a month they so busy,would be cool if you could have a look see what you think,will get her stripped down abit and give you a shout if thats ok,oh will be jacked up in my drive dont have any where inside to do it,thanks col93saphcos
Not a job to do if you can't weld good, not a good one to practise on anyway.
The longest job if you do the whole thing is going to be removing old one and prepping area so it's perfect for welding new one, will be good forever with new one though, will outlast rest of car .
hi all,just to say after many evenings and weekends of working on her on the drive outside,passed mot today,chassis wasnt to bad so patched it and any other bits i could find,fitted 6 degree rear beam aswell,so,well chuffed,im off for a blast now,thanks to everyone for advice etc and many thanks to stucos for advice and parts etc,thanks again col93saphcos
JoeyBoyden
04-01-2024 02:36 PM
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
