different t34 turbos?
in very basic terms
.48 - very quick spool up, but normally runs out of steam at high RPM
.63 - not as quick spool up, but can still provide power at top end of RPM
.55 is in between the .48 & .63, the best of both worlds
i had t34.55 on my road car and was very happy with it
I am also curious to know what exhaust housing I have on my Sierra Cosworth T34, is it possible to measure the outside diameter on the house to get this info? And if so, what figures should a .48 or .55 have?
I cant find this number on mine T34.
I am curious to know what exhaust housing I have on my Sierra Cosworth T34, is it possible to measure the outside diameter on the house to get this info? And if so, what figures should a .48 or .55 have?
I cant find this number on mine T34 and I am not planning to look inside the turbo for now.
One good member here told me it could be .48....
i do not know what the measurements are; can you see any numbers on the exhaust housing.
maybe if you post up some pictures of the turbo; i might be able to tell you what you have
[IMG]file:///C:/Documents%20and%20Settings/Eigandi/My%20Documents/My%20Pictures/RS%20Cosworth/Picture%20154%20%28Medium%29.jpg[/IMG]
Hmmm I was not able to send it here, can I send it to you on e-mail or can you advice how it is done here?
Okay, here comes the picture, I hope you can see the size...
nice discussion,
can someone tell me who's selling the .55 housing ? I'm gutted because my T34 is to small (.48). Even with massive cam and very strong actuator it spikes at 25psi and collaps to 15-16 psi. I'm working with the french cosworth so dont shoot me. The engine was build by a friend from the UK and i finished it. i'll tought it had the .55 turbine...but its the 48.
http://www.youtube.com/watch?v=NzMhbPbPsws
Cheers, Jo (Belgium)
nice discussion,
http://www.turbotechnics.com/docs/index.htm
http://www.crturbos.co.uk/
turbo technics are the only company that actually make the .55 housing!I doubt they will sell u just the housing,they will want to sell you just the turbo(they will probably say they dont have enough in stock!)you might be able to get a company someone like tony at turbo systems to supply you one via turbo technics,they are not cheap around £360 just for the housing!you might be better off trying to get a .63 as these are more common and usually alot cheaper
every escort i've ever stripped have eith er had a .55 or a .48 fitted if they were standard
i had 1 in that was around a year old, totaly standard and among other things it was getting a .63 fitted, which was quite noticably bigger than the standard 1
so i still stick with them being smaller than the .63 standard
i cant see them all having been changed(inc the 1 above) for smaller housings before i got to them
