Correct boost pressure question
Last Time, Get Off PF FFS
this question has probably come up loads of times. but anyways.
i read that the correct psi pressure for a stage 1 4x4 saph cossie is around 14.5 psi. is that correct. cause my one is stage 1 with a hybrid t34 standard injectors and a 500 cooler, -31 actuator mongoose and a k&n. now the thing is my secs monitor and boost gauge read out 17.8 psi.
i am guessing this is not safe and that my injectors are screaming for mercy and making the car run quite lean. or is the boost i am runnig ok. if not i can wind it down as i have a boost bleed valve in-line with the actuator.
many thanks
many thanks
i would say peak but then drops to i think it was 16.5 psi. maybe it is time for another set up. it was last done a year ago. but i have a slight water leak and want to find it and sort that out first before i give her a session on the rollers. might have a look though and see what chip is in it. cheers guys.
JK12
33
26-04-2021 12:09 PM
