With or without dump valve
Received 1,044 Likes
Ive got a saff cossie 4x4 its got a stage 2 chip with greens and a 3 bar map sensor. My car has got a forge dump valve. Ive had this daft running fault on my car and a lad i know reckons the dump valve was leaking cause when you put your hands round the dump valve you could just to say hear it. He took the dump valve off and the fault i have is still there. Is it safe to run the engine without the dump valve. I quiet like the sound of the turbo chatter compared to the noise of the dump valve. So is it safe to run the engine without the dump valve.
Last Time, Get Off PF FFS
would the actuator get knackered more though inc the turbo, cause my hose running from the inlet plenuim to the dump valve came off the other day. no dump valve acton, but loads of lovely wastegate chatter which sounded awsome.
Passion for Fords!
even if your dump valve is leaking it wont cause actual running faults, unless its leaking on the small vac pipe side....the dump valve is before the throttle body....
if it leaks you just have to work the turbocharger harder to acheive your desired plenum pressure
now mate still there then have to check a few things when your back through and do a proper leack check if its still there it wasnt down to dv but it was defo leaking
its a diafram dv and they aint the best if you still want a dv ill swap you for a piston one if you want
it has a problem that means it keeps on throttle when you let off but not for a large amount of time
just a little then drops off ill check it over properly next time he is down but id sugest a senssor set and make sure the rest of it is ok
didnt get chance to clean it the other night but the best way to do it is take it apart give it a thorough cleaning then put it back together and lube it with brake fluid i find works realy well as lube like wd40 dries out tooo quick
Thanks Jacko your a star.I just like my car to be right.I will have to get some money and get a full sensor kit off you.I just dont like asking you Jacko cause your a busy man.I just want my car to be right just like the rest of us.Cossies arnt getting any younger.
I dont like borrowing things i would rather pay for them first.But thank you.I will see mark and see if he wants to pop down another night thats if you will still be there after 6.Or i could pop down at the weekend.
I would never run without a DV either, you have eliminated the dv as the cause of the
noise, it is no doubt just general air moving noise that was heard.
What precisely is the runninmg fault ?
You may find you have a heap of lag without a dv as well.
The sound is NOT wastegate chatter as been mentioned it's simply boost pressure being forced back through the system from the front of your butterfly when closed until it finds a way out.
Normally your DV takes care of this and opens to 'Dump' the pressure to atmosphere but without it will go back till it can get out through the turbo.
'Chatter' as it is nick named is actually your turbo stalling, the sound is the air being forced back through the turbo blades and is not good for anything.
The car when new was also fitted with a DV.
Kind regards,
Martin.
The fault is when its a cold day and i start my car up and drive it the revs feel as if they are sticking on and you can take your foot of the throttle pedal and the car will drive itself for a bit.It just feels like the choke is coming on and off.I went out in it last night,it was a nice night and not cold.It didnt do it last night it drove really nice.Like i said it only does it when its cold,im thinking it might be the ISCV sticking.
Did Someone Mention TUV
i have never understood why people say you will siffer more lag without a dump valve. Surely dumping a boost pipe full of air out into the atmosphere will create more lag as you then have to fill it up again the next time you plant your foot down. With no dump valve there is no where for that air to go therefore the boost pipe doesnt need re-filling so to speak? I found my cossie more repsonsive through the gears without one tbh
Plus i ran my t34 at 2.5 bar peak without a dump valve and all was ok
Now i use a gt30 i have no choice but to use one. Isnt as annoying as i thought it would be
Cossiemodo
Without a DV (like I run on T34) you can keep some of the pressure in the pipes & intercooler, and the turbo slows down a bit/lot... or run with DV, you lose the pressure in the pipes & intercooler, but the turbo slows down much less.
So which causes more lag? Loss of pressurised air, or loss of turbine speed?
And shall we factor in the size of the intercooler? The size of the turbo?
All interesting stuff! I run without DV because they sound gay.
More boost Igor!
Though the thread's not intended as a debate on lag with or without, my experience is that I get more lag without, much less with a dump valve fitted.
The lag stems from the compressed air having nowhere to go with the butterfly shut, hence, stalling the turbine. Try putting a food mixer into solid chocolate and see if the beaters spin faster than when they're in the air. Ever stall an engine when you snap the clutch up too quick when pulling away? Did it make the car go faster? Methinks not. The turbo stalls, air goes back the other way, and when you open the throttle wide enough to spin it up again it spools up only to be stalled when you let off by blocking the compressed air's path again. Personally I love having my own pigeon under the bonnet, but I just can't live with the lazy boost.
If you drive at full throttle (or even mildly wide throttle) all the time, you probably won't notice a difference, particularly with big boost, ie 2 bar. I know I certainly have to wait longer for the boost to build up, particularly on part or light throttle with my weeny T3 at 1 bar.
I prefer the noise without the D/V + when i got my car mapped by Karl @ NMS he said i dont have to run a D/V and with his knoweldge i aint arguing with that
btw its a t34.48 spiking 30 psi, coming to 26 and holding 20psi at top end if that helps/makes sense to anyone
reiss k
reiss k
Karl is indeedy a clever chap, but he didn't say you couldn't.
This has got me so intrigued now I am going out in the car later and try both ways, though personally I don't like chatter.
Very interesting to hear others views/experiences though.
Ive seen your resto mate i will keep an eye on it.I will clean my iscv out this weekend and lub it up.What is the best way to do it.Shall i leave it to soak for a few hours to lub it or just put some lub on and then refit it.Ive been told to use brake fluid to lub it.
