urgent help needed
urgent help needed
just put my engine back in but will not start
it has no spark someone has told me it could be my crank sensor
so need to no asap how to test it thanks.
dont think i have, the only other sensor plug that is anywhere near is my dizzy cap one, but that is black so i no its not that one
the gap is right
i put a plug in the lead to watch if there is any spark.
when i turn the ignition on and of there is a spark
but no spark when you turn it over
spelling
spelling
when i put the ignition on i can here it kick in.
but i noteiced somthing if my dizzy cap isnt pluged in it dont kick in till i plug it back in, is that normal.
also spoke to a mate and he told me it shouldnt be sparkin when i turn my ignition on and off.
speling
speling
still no spark
been tryin to fix it for ages no with no luck anyone got any ideas why i have no spark
problem still the same. when i turn the ignition lights on and off i get a spark but when i crank it over nothing.
any help please
spelling
any help please
spelling
maybe stupid question, but have you checked the timing is right? dont know if its wrong it just sparks at a wrong point or it doesnt fire at all...
yes mate checked it a few times
i was told if it wass rong it still sparks but not at the right time.
i have checked it from the coil wire aswell and its the same there as the plugs
The ignition timing is fixed mechanically by the CPS alignment with the crank pulley, so if valve timing is correct so is igntion timing, though it is possible to get cross firing in the dizzy cap, but it's not this otherwise you'd have a spark.
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
