xr4x4 shaft problem
Cornish Fasty
xr4x4 shaft problem
went about fitting my xr shafts tonight and i can't get the bottom joints in. is there anything on the strut that needs undoing, or do i just need another pair of hands to force it in?
Ta
Dave
Ta
Dave
Cornish Fasty
yeah, i'm doing the job on my own and i can't get it in. normally there is enough in-out movement to manage but the shaft is that much longer, i can't do it. reckon it will go in with an assistant holding the hub, and me moving the bottom arm?
Easy way to do it one person, is to place a bar resting on the arb,and the other end rest it in the gap where the inner endof the tca is, as it is held in there inside the gap bit , use one about 2 1/2 feet long, this way you can put your foot on it and push down whilst manouvering the hub/tca together.
Cornish Fasty
well, even two of us had no joy, so decided a better option as robbing the inner joint off one of the xr shafts and replace the cos one. jobs a good'un.
all for the twat buying to let me down on the deal.
ho hum
ho hum
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
