cosworth Compression??
Do you mean compression ratio or what you should see when doing a compression test??
Comp ratio 8:1 iirc
Should see about 150 -160 psi I think when doing a comp test, Im sure someone will confirm/correct me.
Comp ratio 8:1 iirc
YES I KNOW I CANT SPELL
As said throttle makes no difference, some do a dry test, then a wet test, and this can give you an indication if your rings are worn, ie if wet test goes up noticeably due to forming a better seal you may have problems, if it stays the same and one pot is low you know it's a valve problem.
I alwasy take out all the plugs as they have to come out anyway and leave out whilst doing the test all the plugs, as it's easier on the starter as well.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
Adam Graham
06-09-2015 06:04 AM
