Boost Controllers..
Boost Controllers..
Who runs one and which one is it..
I want to calm down that whack in the back with a controller, but confusin myself.
I used to run the Apexi AVCR on my S2, but there is no spd sensor on the saph' so the boost mapping for individual gears will not work..??
The Blitz looks ok, but needs the power ID as well to open the speed map function.
Or go for the Greddy Profec B, pretty simple with just 2 profiles and adjust the spool up properties. But then i may as well just have the hi-lo boost switch set up..lol
I'll look into that and see if* the ABS signal will do the job.
copied from the Apexi manual..
Y32 Cedric/Gloria :16
Y32 Cima :16
All other NISSAN vehicles :2
All other JAP' vehicles :4
no real clue as to what that means, id guess its pulses per wheel rotation..??
Im guessing the ABS hub has in excess of 30/40 pulses, or castleations..??
Might jus go for the hi-lo boost switch
Y32 Cima :16
If your map is allowing a boost spike then fitting a controller for the final boost will make it run rich in the mid range
who's chip what car??
I used to run a profect spec b but after fouling plugs due to rich in the mid i went back to the amal valve along with the spike
Paul
Paul
Paul
Paul
If i remember right, you can set the AVCR with the spike, flat, or a negative spike if that makes sense..?? Makes more sense when you see the set up graph.
i've got a AVCR, and Fiecos Dan pointed out that stuff running EECiv uses a speed sensor and a cable. i'm using one off a mk7 escort, and the sapph cable goes straight onto the top
What have you got yours set too & do you get a reasonably accurate reading for speed..??
cheers, Nik..
Right then from experience Stu maps with a spike to give more mid range torque and a little more power
Imo would be a good idea to run it past him first and if you buy a controller before he can fit it and set it up and if you want depending on price he can alter the chip to suit your requirement
Job done
Paul
Job done
Paul
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
