is there a diffrance????
Old 05-08-2008, 07:56 PM
SWIFTY
SWIFTY's Avatar
Default is there a diffrance????
are all 205 pinto blocks the same????
are the 2wd cosworth blocks the same as a normall 205 pinto block as found in the rs2000 except the internalls.
in other words, could i use one of those pinto blocks and my internalls.
thanks
Old 05-08-2008, 08:19 PM
mechanic28
mechanic28's Avatar
i beleive it is the same yes,but i think the best 205's were used on the cossies?
Old 05-08-2008, 08:27 PM
SWIFTY
SWIFTY's Avatar
cheers mate,
anyone got any idea what these numbers mean?
Old 05-08-2008, 08:30 PM
mechanic28
mechanic28's Avatar
aint got a clue fella sorry maybe build codes etc?
Old 05-08-2008, 08:42 PM
RS 5tu
RS 5tu's Avatar
How much is a 205 pinto bottom end worth there is one where i work doing nothing.
Old 05-08-2008, 08:45 PM
SWIFTY
SWIFTY's Avatar
normally about 50/60 quid mate, depends whats with it
Old 05-08-2008, 08:47 PM
RS 5tu
RS 5tu's Avatar
just rust, he wants rid if any one want to make he a offer. cheap cheap.
Old 05-08-2008, 08:49 PM
SWIFTY
SWIFTY's Avatar
oh that'll be about 100quid then, rust's fetchin a fair bit these days lol.
can you get me the codes of it when your next in work please, if there the right ones i'll have it off ya.
Old 05-08-2008, 08:50 PM
RS 5tu
RS 5tu's Avatar
ill take a pic tomorrow, Prob get weighed in soon tbh if no one wants it
Old 05-08-2008, 08:51 PM
SWIFTY
SWIFTY's Avatar
ok mate sound. just pm it me
Old 05-08-2008, 08:53 PM
RS 5tu
RS 5tu's Avatar
think its "ru5ty 205"
Old 05-08-2008, 08:56 PM
SWIFTY
SWIFTY's Avatar
exactly what im after
lol
Old 05-08-2008, 09:34 PM
saph cos rob
swindon rsoc
saph cos rob's Avatar
205 blocks are all the same, the only special they made was for the rs500 205 block which the only noticable difference outside is the smaller core plug holes, but i belive the liners etc are thicker internally.... the 200 block as we all know are the ones to get but finding a good one for reasonable money will be a mission! many a person i know have run over 400bhp with a complete std 205 bottom end.......
Old 05-08-2008, 09:44 PM
LHD220Turbo
LHD220Turbo's Avatar
i thought all rs500's had 200 blocks?
Old 05-08-2008, 09:50 PM
bortaf
bortaf's Avatar
thanks
RS2000 never used a 205 block it used the early cortina 2.0 block, sorry to sound pedantic
Old 05-08-2008, 09:56 PM
saph cos rob
swindon rsoc
im almost 100% sure in saying the was a special 205 block made for the rs500??????? but i very much doubt your ever see 1 forsale!!!!!!! lmao
Old 05-08-2008, 10:12 PM
benporter
benporter's Avatar
corect
Old 06-08-2008, 09:46 PM
AndyPen
AndyPen's Avatar
Yep, correct about the rs500 205 block. I was lucky enough to buy one and they don't come cheap! My car previously ran around 350bhp on a standard 205 block.
Old 07-08-2008, 04:26 PM
SWIFTY
SWIFTY's Avatar
So If I Buy A Standerd 205 Pinto Block Out Of Any Thing An Use My Internalls It Should Work And Be The Same Strenth
(spelling )
Old 07-08-2008, 04:32 PM
ickey818
ickey818's Avatar
cheers mate,
The 85HM 6015 BA is the original Ford part number, i.e the number on the engineering drawing not the Fins number used at the dealership / spares department.
Not sure what the other numbers are though.
Old 07-08-2008, 04:37 PM
SWIFTY
SWIFTY's Avatar
thanks mate
thats the same number as on mine so does that mean there the same block???
Old 07-08-2008, 06:55 PM
ickey818
ickey818's Avatar
It means the blocks are the same design but I'm sure the Cosworth blocks where hand picked based on the bore tolerance after machining.
From memory I think if you look by the distributor there are four numbers stamped in the block. These dictate the class of the bore after it was machined, think there were 4 classes in total. I'm sure the blocks for Cosworth engines only used class 1 or 2 bores but I maybe wrong.
If your having the block re-bored anyway then it shouldn't be a problem.
tomoyb
29
01-09-2012 10:19 PM
cosworth it
23-12-2009 09:12 PM
scoobypete
12-06-2009 02:13 AM
RabReith89
24-05-2009 12:00 PM
SWIFTY
12
30-09-2006 06:12 PM
Quick Reply: is there a diffrance????
