PAS Pipe removal
Old 27-01-2007, 05:39 PM
broos3
broos3's Avatar
Location: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
Default PAS Pipe removal
I broke the fitting on the pipe that connects the PAS pump to the rack so i need to remove the rest of the pipe.
How do I remove the pipe from the rack. The car is a 2wd cosworth. There is a plate and an 10mm AF bolt securing it to the top of the rack. I have removed this but can see how to remove the pipe.
Any advice??
Also anyone got a pipe i can have?
Thanks Bruce
Old 27-01-2007, 07:07 PM
RONNIE AMIS
RONNIE AMIS's Avatar
the plate holds both pipe's in, once you've undone the 10mm give the pipe a wiggle and it will come out, its got a rubber o ring to seal it so it might be a bit tough getting out
Old 27-01-2007, 07:34 PM
broos3
broos3's Avatar
I thought that was the way to do it. Just never had the balls to give it a good wiggle.
Thanks mate.
Anyone have the said pipe??
Bruce
Old 27-01-2007, 08:08 PM
Alan s1
Alan s1's Avatar
I was going to say my Engine and box is out atm i coult get a pic of the rack tomorrow if needed but sounds like you have sorted it
Old 27-01-2007, 08:10 PM
broos3
broos3's Avatar
Yeh mate got it sorted. Thanks for the help though.
Bruce
Old 27-01-2007, 08:17 PM
Alan s1
Alan s1's Avatar
Old 29-01-2007, 10:13 PM
Sideways_Sierra
Sideways_Sierra's Avatar
How did you snap it ?!
Old 30-01-2007, 09:00 AM
dojj
Resident Wrestling Legend
dojj's Avatar
just remember which way the pipes come out and, if you haven't already, be preppared for it to make a huge mess on the floor
Old 30-01-2007, 04:49 PM
broos3
broos3's Avatar
I snaped the fitting from the pipe trying to take it out of the pump.
As for the other end of the pipe (going into the rack) Its not wanting to come out. The bolt and the plate are removed but its seized inplace. I think i will wait till I get a new pipe then try and get the old one out.
any other thoughts?
Bruce
Old 30-01-2007, 05:46 PM
dojj
dojj's Avatar
twsit it gently
the only thing thats holding it in place if the rubber seal
just make sure you get new ones with the pipe you are replacing it with though
Old 30-01-2007, 06:03 PM
broos3
broos3's Avatar
Originally Posted by dojj
twsit it gently
Yeh i have tryed to twist and pull. But its not coming.
Do you mean buy a brand new rubber seal and fit it to another old pipe? Make sence to fit a new seal if thats the only real thing that makes it liquid tight.
Bruce
Old 31-01-2007, 05:01 PM
broos3
broos3's Avatar
Any more coments?
Bruce
Old 31-01-2007, 05:20 PM
dojj
dojj's Avatar
if it's broke at one end you might as well break it at the other if it won't come out
worst case scenario is that you wil lhave to remove the rack, but as it's 2wd it's a doddle, pull the 2 bolts out that hold it in place, undo the 10mm bolt that holds the steering shaft to the column just by the bulkhead, undo the tca's and out it comes
with it on the bench you'll have much mroe time to be delicate with it and it might just need a bit of gentle persuasion with a punch to knock it round to break the seal a bit
if you are worried about the other pipe you can thread that through the engine bay while you remove it, not the end of the world if you have to replace it as well but make sure you've got replacements before you go that route
remember to make sure which pipe goes in which hole though
Old 31-01-2007, 06:37 PM
broos3
broos3's Avatar
Thanks Dojj.
I will have a go at it. Yeh thought about taking the rack off, looks fine to do.
Bruce
Old 01-02-2007, 06:50 PM
dojj
dojj's Avatar
if i can brave the elements i'll go and take a pic of what you need to be removing
Old 01-02-2007, 07:06 PM
broos3
broos3's Avatar
Dojj,
Its ok mate i know what im doing. Was just needing some pointers in how others have done it in the past as mine was seized in.
Bruce
jonfoc
16
11-09-2018 05:35 PM
cossie330
07-10-2015 08:22 PM
Fudgey
17-09-2015 01:06 PM
R4N SS
Ford XR Parts For Sale
15-09-2015 03:38 PM
Quick Reply: PAS Pipe removal
