What about spark plugs?
13-10-2006, 10:02 AM
Hello
My car is a Ford Sierra Cosworth 2WD stage 3 (24psi of boost)
For the moment, I use
Bosch f3cs spark plugs.
I will want to replace them by
denso ik27
Do you think that it is a good idea?
thanks
JY
13-10-2006, 10:52 AM
Sponsor
there a few lads on here that use them with good results but personly i use o71c's from ford finis code 1120834 there about a tenner and spot on for your car
13-10-2006, 01:30 PM
071's are good plugs.
19-10-2006, 08:56 AM
nobody else?
19-10-2006, 11:43 AM
i run densos on mine, no probs, although they are very cold plugs apparently?
19-10-2006, 12:26 PM
what is your denso model?
what is your car?
19-10-2006, 07:59 PM
So you seem to want to run Denso's really badly....
Most people on here with modified Cosworths will be running 071s.
There's a tonne of threads in this forum if you do a search on spark plugs.
Ford 071's Motorcraft spark plugs
Finis code 1120834 AGPS 071C
19-10-2006, 10:22 PM
mine is stage 3 and i run denso plugs, bit expensive but do the job
20-10-2006, 02:25 PM
20-10-2006, 09:06 PM
Live long and prosper!!
i run PP8's with no probs but going to change to NGK R1's soon
20-10-2006, 10:28 PM
Quote:
what is your car?
IK27's
Saff 4x4 running NMS Gunship+ conversion
20-10-2006, 10:33 PM
Whats the difference between IK31's and IK27's ?
well actually i am not sure what state of tune you would call it, just looked on the NMS website and its stage 3
20-10-2006, 10:39 PM
Quote:
about 4 if my calculations are correct
20-10-2006, 10:55 PM
I run 071c's good plugs but need re gaping every 2-3000mls and only last bout 5-6000mls imo
20-10-2006, 11:20 PM
i run ik27s in my car with no probs..just changed them after 7k miles...
nothing wrong with old ones but did it as part of a service...
good plugs..
21-10-2006, 07:47 AM
The IK27’s are the equivalent heat range of a 9 in the NGK range and the IK31 is a heat range of 10 in NGK.
I use the IK27’s on the street and IK31’s on the strip/track.
21-10-2006, 09:54 AM
Normally, the other interest of denso iridium is to have a very long life.
The guys who use the IK27 have which level of tuning?
27-10-2006, 09:05 AM
There is a lot of model!
Which spark plug is really the best for a "normal" use and some big boost (24psi) some times?
Iridium (Denso, NGK) one have very long life?
Pp8 too?
01-11-2006, 02:03 PM
RS & ST Parts Specialists
01-11-2006, 02:32 PM
01-11-2006, 02:53 PM
Passionford Thread Killer
071's are nice and cheap to, only they made my 4x4saff run like shit when I gave it stick.
I like the champion QC59C's, race plug so they make the car hunt a bit on idle when cold though.
06-11-2006, 10:27 PM
What gap do people set them at for 071s?
07-11-2006, 09:22 AM
For a std car- 0.85-1.0mm
For more boost(depending, less gap if running more boost)- 0.85-0.65mm.
Watch out on the 071's though because they are offset, you have to gap them at about a 45degree angle.
07-11-2006, 04:16 PM
Denso IK31's
08-11-2006, 08:29 AM
for peoples which have
DENSO , how much miles can I hope with ?
which model you have and what boost?
for 071 spark plugs, is it standard plugs or platinum?
and what aboot PP8 for 24psi?
13-11-2006, 06:11 AM
I also run 071 plugs...but they seem to misfire now and then when on full boost (I run a stage 3 with 23psi boost and I have gabbed them at 0,65 mm).... so I'm trying to figure out what to do...new gab or new plug ..????
13-11-2006, 08:02 AM
Hi Tom.. I am having the same problem Tom.. not funny!! I would sell the car
Back to the topic:
Where do you buy you DENSO´s???
13-11-2006, 09:37 AM
Quote:
Back to the topic:
Maybe I will...
14-11-2006, 05:38 AM
Are motocraft's AGPS 092C1 good for 2WD standard (next year stage 1) cosworth? My friend has bought this sparg plug by ford and they say that's for cosie
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
Brickhouse
14
03-10-2015 07:28 PM
deathrider666
28-09-2015 06:12 PM
071 ,
bosch ,
cosworth ,
denso ,
difference ,
equivalent ,
f3cs ,
ford ,
heat ,
ik27 ,
o71c ,
plug ,
plugs ,
range ,
sierra ,
spark
