4x4 service questions, quick ones
Few quick questions regarding to the servicing of my saff that I will get on with soon:
Does the 4x4 cosworth engine have a replaceable sump plug washer?
Does it have an air bleed when it comes to refilling the coolant system?
If I upgrade to a group a coil from my standard one, will I need the car setting up? as i am fiitng ne plugs too, gap size? (20 psi stage 3 )
Cheers guys, much appreciated, possible more to follow
No.
I bled mine at the thermostat housing.
No you wont need it set up.
No.
No. CHEERS
I bled mine at the thermostat housing. HOW?
No you wont need it set up. GOOD TO KNOW, JUST REPLACING PLUGS AND COIL.
No. CHEERS
r
Adam Graham
06-09-2015 06:04 AM
