Big spec rst unbuilt engine and gen ford cvh oil pump
Old Sep 15, 2013 | 06:13 PM
lozi's Avatar
lozi
My Cossie Ate My Money
Default Big spec rst unbuilt engine and gen ford cvh oil pump
Due to a recent operation I sold my Mk2 Fiesta so my RS Turbo engine is up for sale.
I want it to go together as an almost ready to build engine so will not be splitting unless it doesn't sell together.
4 x Wossner 8:1 CR Forged Pistons 81mm
4 x PEC Steel conrods
ARP conrod bolts
ARP head stud and nut kit
1600 CVH EFI block, decked, bored and honed +1mmfor the above set of pistons, its got abit of surface rust where it's been sat in my garage but it should be ok
Standard RS Turbo crank which also has a little surface rust from storage, reground and polished +0.25mm with ACL HD bearings to size (mains, big ends and thrust)
Ported EFi cylinder head rebuilt by jano oddkidd with Newman PH4 Cam and solid lifters, new valves seals etc and new 5 angle valve seats cut. I believe this head has never been skimmed.
Gaskets for classics gasket set
new water pump from matt lewis
Ferriday thermal inlet gasket
If I get the asking price I will also throw in some cam covers and charge carriers (EFi and mfi) and an auto specialist oil cap if the buyer wants them
EDIT: I will now also include this sump which has just been baffled & gated and powder coated if it makes asking price
I'm looking for £1300 for this setup cash on collection from Towcester northants
You can contact me on here or 07894705036
Old Sep 15, 2013 | 06:17 PM
lozi's Avatar
lozi
I also have a genuine ford late type cvh oil pump brand new in box
I have priced this strongly at £300 but it took me months to find one and I had to get it from Germany in the end.
Old Sep 15, 2013 | 06:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Nice engine waiting to be built there!
I personally would sell the stud and nut kit separately as they are no use on a turbo charged CVH, many head gasket failures have been attributed to there inability to expand like normal stretch bolts do.
Old Sep 15, 2013 | 06:44 PM
Ben26's Avatar
Ben26
1300 wow. That seems a bit to much imo.
Old Sep 15, 2013 | 06:58 PM
lozi's Avatar
lozi
I'm open to offers but it would cost over twice that amount to assemble these parts yourself/have the machinng etc done and its mostly new parts
Old Sep 16, 2013 | 12:48 AM
rsmark86's Avatar
rsmark86
sell it seperately, i stuggled to get £850 for a fully built engine of the same spec, with an oil pump complete with 3k miles from new and was mint and had arps, genuine ford gaskets and head bolts, baffled sump the lot
worth more in bits
its a sign of the times as i sold one simular with a fully worked head big valve head a few years ago and got £1500 back then
Old Sep 16, 2013 | 08:18 AM
lozi's Avatar
lozi
An unbuilt engine will be worth more than one that has been built and run or at least would be to me anyway I would much rather get it built myself than trust so somebody else's work.
I could include a baffled sump with this engine but the buyer would have to wait till it arrives as I haven't even received it back from the company doing it yet.
I will split if it doesn't sell but I have no idea about individual prices which is one reason I want it to go as a whole
Old Sep 17, 2013 | 02:34 PM
lozi's Avatar
lozi
Baffled and gated sump added
Old Oct 11, 2013 | 12:24 PM
TIL13R's Avatar
TIL13R
Same spec as mine... I spent alot more than this... Great Price...!!!
Old Oct 11, 2013 | 01:31 PM
Canada1's Avatar
Canada1
I agree the standard stretch bolts are the best choice for reasonable boost levels on a CVH (25 psi) They are designed as nearly fool proof.
The many head gasket failures with arp studs is not because of the studs inability to stretch. All fasteners stretch to achieve clamping force. Stretch bolts are stretched further (can't be re-used) which requires no re-torquing (after head gasket compresses over heat cycles). Failures occur when studs are not installed correctly and not re-torqued after a few heat cycles.
Old Mar 9, 2014 | 03:59 PM
Paul Dolman's Avatar
Paul Dolman
hi lozi, did this go or do you still have it?
Old May 7, 2015 | 09:38 AM
Kingabe's Avatar
Kingabe
Did you manage to sell this mate?
Old May 7, 2015 | 04:47 PM
Paul Dolman
im pretty sure it's gone, i wanted the oil pump but i'm sure he sold everything together
Old May 7, 2015 | 06:34 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
yes I built this back up recently.
Old May 7, 2015 | 06:55 PM
Kingabe's Avatar
Kingabe
Is it for sale!? Jano, I spoke to you breifly at Central day with Ramin. You managed to sort that misfire out yet?? Basically my rs turbo has given up on me, rings I think. I'm looking for a decent standard engine or a recently rebuilt cvh or Zvh to stick in it. Know of anything around?
Old May 8, 2015 | 07:35 AM
Versus_Creations
Ask me a question!
I cant offer parts for sale on here pal.
big_Rad
Sep 15, 2017 09:36 AM
dlwarrior
Aug 5, 2015 10:19 AM
Blown Hell
Aug 5, 2015 07:22 AM
Escortdriver1
Jul 31, 2015 02:36 PM
