Ford Puma Discuss the Ford Puma here!
Fuel Gauge
Old Dec 6, 2012 | 04:51 PM
s6boy1979's Avatar
s6boy1979
Default Fuel Gauge
Since i bought my puma about a month ago the petrol gauge has not worked. It still on full all the time while the ignition is on and drops to empty when i turn it off so the needle moves and is working. I have changed the sender and is it is still doing it so i am stumped as to what it could be.
Old Dec 12, 2012 | 08:58 AM
STeve's Avatar
Super Moderator
you have changed the biggest and most awkward part so it must be a gremlin on the cluster Ian
Old Dec 12, 2012 | 09:12 AM
s6boy1979's Avatar
s6boy1979
Not a clue what it is and no one else seems to know either!!!!
Old Dec 12, 2012 | 04:29 PM
STeve's Avatar
Super Moderator
Ian this is a common thing on fiestas/puma especially the mk5, Check continuity from the sender to the gauge with a multi-meter. Also check resistances and check your earths are ok but you will prob needs a haynes manual to ref
Old Dec 12, 2012 | 05:05 PM
s6boy1979's Avatar
s6boy1979
That's was my next step this weekend
Old Dec 14, 2012 | 11:25 PM
s6boy1979's Avatar
s6boy1979
Ok i am really confused now!!!!
There has been no change with the gauge. I noticed the other day that i had a fuse missing from the fuse box in the engine bay. After checking it is for the EEC module. I fit one and no change to the car in any way. I did this Thursday night.
So Friday evening after driving the car to and from work i jump in to pick my some up, start it up and while i got myself sorted a heared a loud thud, like something had been dropped on the roof. I jump out look fround the car but cant seee anything so think nothing of it.
As i am driving the gauge slowly starts falling and stops at half a tank and stays there for a little while then very slowly creeps up to three quarters!!
After a 30 mile trip i leave it stood for about an hour before the journy home. Start it up and sit on half a tank again. I put £20 worth of petrol in it but the needle does not move. So now it reads half a tank but does move very slightly over half a tank but then back down.
I am so confused now.
Old Dec 18, 2012 | 12:17 PM
PumaJay's Avatar
PumaJay
must be a problem with the instrument cluster itself, have you had it out and had a look round it?
Old Dec 18, 2012 | 12:25 PM
martysmartie's Avatar
martysmartie
Check the reference wire has not shorted to ground, if it were the cluster you would almost certainly have more issues!
Martin
Old Dec 18, 2012 | 12:53 PM
s6boy1979's Avatar
s6boy1979
Not had the gauges out as the gauge does move when you do the gauge test and when turning the ignition on and off.
What or where is the reference wire?
Old Dec 19, 2012 | 12:15 PM
martysmartie
On older cars, the resistance the sender has determines what the gauge will show, in other words it's the wire that connects to the sender, you will have more than one I suspect for fuel light etc, I suspect the wire is the problem!
Martin
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
