Ford Puma Discuss the Ford Puma here!
ford puma lowerd 60mm
Old Jun 3, 2009 | 05:29 PM
stephen g's Avatar
stephen g
Default ford puma lowerd 60mm
i have been looking for 60mm springs for my puma but cant find any anywere all i can find is 40mm the only other thing is coilovers but that will be a last resort will fiesta springs fit ?
Old Jun 3, 2009 | 05:50 PM
damo86's Avatar
damo86
Just cut the ones you have. Cheapest option. And is 100% safe.
Old Jun 3, 2009 | 05:54 PM
stephen g's Avatar
stephen g
no way mate it getting done the right way lol .
Old Jun 3, 2009 | 07:13 PM
RichieST's Avatar
RichieST
Old Jun 3, 2009 | 07:52 PM
Dal_'s Avatar
Dal_
I've only ever seen the likes of Eibach that go -40mm. As you say, coilovers are the best way to get 60mm low. With a drop of that much, you'll probably need to cut the inner front arch away at the top (the same as how FRP's are) otherwise you'll rub. Especially if you're running 17" wheels (7" wide) You'll also get inner tyre wear as there is no adjustable camber on a Puma unless you get adjustable lower arms.
Old Jun 3, 2009 | 09:39 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
drop 60mm on standard dampers and youll fuck both your tyres and handling just so it looks "bling, innit bruv"
Ben26
Aug 27, 2015 08:56 PM
borboyous
Aug 22, 2015 11:17 AM
Ben26
Aug 11, 2015 04:19 PM
Aug 10, 2015 12:08 PM
