mondeo flashing glow plug light??
hi my dad has a 2006 mondeo 2.0 tdci 115ps ghia. the glow plug light flashes on it from time to time it runs fine but sometimes its down on power and runs rough. if he stops and restarts, everything is fine for a while and the light goes out.The car has 127,000miles on the clock and puts out heavy black smoke under hard acceleration . I have a can eobd 2 diagonstic s that I purchased of ebay . i ran a scan but not showing any faults or codes,any advice would be appreciated confused
Get it scanned with a Ford specific scanner.
It may not show any codes after restarting the engine, so the best method is to read the codes when the glow light is flashing.
the scanner is an autel it was a cheap purchase of ebay . as the light is not flashing all the time it seems to be an itermittent fault , so getting it to do it with the code reader plugged in may be a hit and miss affair. A trip to the main dealer might be on the cards.
In this case driving around with the Autel is a waste of time.
With this scanner you can only see codes when the MIL is on.
The MIL (Malfunction Indicator Light) is the yellow light with the engine block.
Buy this one
http://www.ebay.co.uk/itm/271288244105?redirect=mobile
The light wasn't on mine either but this was able to read stored codes
Hi mate. I've got an 04 plate 2.0 TDCI. 2 year ago I had the problem of the Glow Plug light flashing and then the engine dying a minute later. Took it to local Diesel Specialist and they put it on their Delphi Rig. To cut a long story short, I had the Fuel System replaced (£1600!). It was fine for 18 months and then Lo and behold, the same thing started to happen again. My car has always been regularly serviced (including Fuel Filter, change!!)
Diesel specialist reckons it is possibly Inlet Metering valve which is an ancilliary of the Fuel Pump or Injector #4. I have always had Fords, but this has really put me off Ford Diesels. Looking at the web, I am far from being alone in having these issues. Friends have had similar issues, and have spent a fortune going to local garages who do not have the equipment to test the system fully and as has been said, all you sometimes get on a code reader is Fuel Pressure Low/High, which could be anything in a Common Rail injector system. Good Luck.
