2001 mk3 mondeo with no o/s main beam, side light & rear light???
Checked all fuses ( in engine bay and behind glove box ) and none blown, replaced all bulbs and still no joy. Took off & cleaned earths front and rear. All other lights work fine
big floppy donkey dick
put it on 20v, make sure its working by using the + and - on the battery for 12v ish or 14v ish if its running.
as long as it hasnt got Xenons take the good side`s wiring plug off and check for + and - at each terminal, draw a little diagram and what voltages there is and if its + or -.
then test the non working side.
same goes for rear lights also.
then its wiring diagram time, doing a continuity check (i.e wire is not broken!) etc
jessie_rs
11
03-06-2019 04:57 PM
borboyous
22-08-2015 11:17 AM
sridgett
15
03-08-2015 07:26 PM
