Mondeo mk3 falling to bits-is it the dmf
Hi all.
First post so here goes.
Got a Mondeo mk3 51 plate 1.8 I have had a 05 engine fitted when bought.car has been parked up for 18 month has had work car it's back out now changed 4 springs front right wheel sounds like it wants to fall off really bad on bumpy roads or speed bumps.sounds like the springs are squeezing on the back of the car.also get a bad wobble on acceleration you can feel it through the car.engine no noise at start or tickover no noise when the clutch is in or out just bad wobble vibrating when driving.could this be a faulty wheel.been to garage who cannot find anything wrong with the right wheel even though it sounds like its ready to fall off.he reckons the dmf is causing the wobbling.but it kind of contradicts itself with what the Internet says I'm getting no noise on idle?it was ok 18month ago when parked up any ideas has to the problems or any ideas to work out if it's the dmf.im sure the garage is chasing the money-it's not the best garage in the world.also had 2 part worn tires. Fitted to this car could it be a faulty tire?.its knocking from the right wheel bad but not the bearing?its doing my head in.has anybody parked a Mondeo up for 18 month and had similar problems?.also unsure if my car has a dmf has I'm no mechanic.but all the garages around just seem to be out for what they can get.
Thanks for your time.
Whos
Whos
Thanks for the replies,joking aside now.i actually was waiting for someone to put set I on fire.
Can some1 explain how to check for symptoms of the dmf going.
Also what makes a tinny rattling noise and occasional big knock going over rough ground or speed bumps only happening on drivers front wheel.
Could the driveshaft be at fault with the wobbling has I had a problem with the driveshaft boot comming loose on the passenger side.
The engine sounds healthy.a few pointers from the experts would be usefull
I have had all the wheels checked for buckles.re-balanced and tracked no faulty tires.
Still have the wobble not has bad though has I had 1 wheel not balanced.
The guy told me he thought my problem was mechanical before he started.mechanic can't find anything to make noise on the front I'm changing the drop links Tom as seem a little worn.now the wobble what else can cause this under acceleration?besides what I have already checked.
Whos
Whos
Thanks for replying I will put these on my checklist for the weekend.out of interest wouldn't warped disks cause knocking on braking? Has this does not happen.it only wobbles on acceleration in all gears feel it more in 5th.
Whos
Thanks for the replies guys I'm going to be looking at the car all weekend now off work.
To answer a few replies.
If I put it in neutral at speed the wobble stop sits only under Acceleration soon as cruising or very low accelerator use the car will go as normal.once I put my foot back down wobble wobble.
The car has been jacked up a few times no play with the wheels no bad bearings and lower arms ok.
Is there anyway I can check the driveshaft without replacing it.?
Also get a movement knock like the engine mounting has gone but engine is stable.
Il have a look an post back any findings.
Unclip the boot where the drivers side shaft goes into the extension and have a look. If there is very little grease, or it runs out as a liquid then its broken down and could of damaged the coupling. Clean the cup with a bit of rag, check for gouges, scores, signs of wear. Check the bearings on the driveshaft knuckle for the same. Rock it up and down inside the cup, check for excessive play.
Drivers side driveshaft changed just the knuckle got a second hand 1.2 link bars.
Car drives sweet now.
Also was informed I have a back bearing to change And drop links on back then car is all fixed.
So much for the garage and the dmf-straight muppets.
The frozen one cheers mate I owe you a beer.
Whos
mk3ste
17-10-2021 10:09 AM
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
