St220 / st200
St220 / st200
Is the Mondeo ST220 engine a replacement for the ST200 or are there other parts that will need changing, like the Controller, sensors any information gratefully received.
My ST200 Has big ends gone, so I am thinking about fitting an ST220 which apparently has some refinements to the sump that help protect the possibility of oil starvation and less likely to big end trouble.
Plus, I am more likely to find a good 220 engine than a 200 that may be on it's way out.
Are you planning on swapping the entire engine over then, or interchanging parts between the two engines?
The "3.0 Swap" is rather well documented on contour.org, well worth a look on there
Si B
12-09-2015 06:49 AM
blakey100
04-08-2015 08:17 PM
ster
05-02-2006 06:30 PM
Daveyraveygravy
07-09-2004 08:53 AM
