xr3i efi fuel pump
The pump if the same as cossie and xr4i, the 941 is capable of around 10 BAR, this is why it has a fuel pressure regulator, to control the pressure in the fuel rail, most fuel rails are between 3 and 3.5 bar.
If it is the standard bosch pump the lockout pressure is 11.5 BAR, HIGHER than that of a cossie pump which is still only 11.2 BAR for the 044(group a).
For your 0 280 254 910 pump is 3.25 Litres/min at 3 BAR.
The cossie one can be safely used even the 044 if wanted.
JK12
33
26-04-2021 12:09 PM
