Abs light on dash and traction control light. Focus st170.
Car has sat for a year. Moved it and both lights came on. Bk caliper was stuck and still sticking abit when driving. Can that cos lights to come on? Or is it front brakes.
Moderator
dead common for rear calipers on these to seize up normally its the handbrake lever part or the sliders, as for abs sensors they are again a very common item to fail as I sell a lot of these for that reason
If you move the car with one wheel not turning it will trigger the fault. It should reset after so many cycles if the fault no longer exists or it can be reset.
if there is a fault it needs fixing first.
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
midge
08-05-2013 02:04 PM
paulw77
05-01-2013 07:03 AM
vinnyd
Ford Focus RS
21-12-2006 11:39 AM
