ST170 engine light on
Old May 11, 2014 | 01:47 PM
Default ST170 engine light on
My mate from work has a ST170. The engine light has come on it and he said he did 100 mile to half a tank the other night. Does anyone have any ideas. We plugged the ford diagnostic tester in to check to see if the lambdas are working and they seem to be fine.
There was also another fault code which was for the inlet manifold. We the engine is reved you can see that the cable from the control unit is pulling the flap open in the inlet manifold.
Has anyone got any ideas.
Old May 11, 2014 | 02:20 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
That's the IMRC P1518. There was a recent thread on it with a description of the problem.
https://passionford.com/forum/ford-f...ml#post6471041
Old May 11, 2014 | 08:55 PM
kyle_st200's Avatar
kyle_st200
Could be lambda sensors too, think they fail quite often on these
Old May 12, 2014 | 10:21 AM
As above matey. They seemed to be working ok on the ford tester.
Old May 20, 2014 | 03:56 PM
Well last week my mates ST.s engine light came back on again. It was a lambda sensor fault. He replaced both sensors. The car was mint for a week and the light is back on. The inlet flap is sticking open. It looks like the imrc is at fault. We will take it apart and see if we can see anything inside.
Old May 21, 2014 | 09:32 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
when the engine starts does the cable pull straight away?
Old May 22, 2014 | 07:43 AM
LeeBee's Avatar
LeeBee
100 miles to half a tank works out at roughly 22mpg, if he's been booting it that's what he will get, that's roughly what I'm getting
Old May 22, 2014 | 02:53 PM
Pitbull69's Avatar
Pitbull69
I'm getting 21 MPG out of mine regardless of how I drive it, slowly getting used to the idea that its not gonna get any better. luckily I only do under 6k a year,
Old May 26, 2014 | 01:49 PM
I havent noticed.
He said the engine light came back on last week and the fault was the imrc again.
Old Jun 11, 2014 | 09:34 PM
hydro st170's Avatar
hydro st170
Originally Posted by Glenn_
I havent noticed.
U can by pass the imrc then get it remapped 2 let the ecu know that the imrc is not being used and wont have the exspensive problem of replacing the imrc now and in the future as it will go again
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
