Remote Central Locking not working on ST170
Old Dec 30, 2013 | 03:01 PM
Kammy1's Avatar
Kammy1
Default Remote Central Locking not working on ST170
Hi Guys,
I've got My ST170. I have tried a new battery in the fob but this has not solved the problem.
The central locking works when I use the key in the door and this also activates the alarm as it is a pain when I unlock and open the door, the alarm always sounds until I start the car.
Is there anyway I can get this fixed? If not, can I deactivate the alarm (not ideal) to stop waking the street up in the mornings?
Any help would be appreciated?
Thanks
Old Dec 30, 2013 | 03:08 PM
Oranoco's Avatar
Oranoco
Old Dec 30, 2013 | 05:12 PM
GVK.'s Avatar
GVK.
If the above doesn't work, (you get no chime when you press the remote fob) you can try disconnecting the GEM module connectors (under dash right hand side) and reconnect, then try the programming sequence again.
If it still doesn't work, chances are the remote is kaput. Other Ford remotes look the same but for instance Mondeo and Focus do not interchange, even though they look identical.
Old Jan 8, 2014 | 01:55 PM
Kammy1's Avatar
Kammy1
No luck with this as yet guys. Can I just check if the Focus has a 3 button remote or has mine possibly been swapped for a Mondeo one hence why it is not working?
Thanks
Old Jan 8, 2014 | 05:56 PM
GVK.'s Avatar
GVK.
Focus and Mondeo look the same, 3 buttons, rounded fob.
Old Jan 14, 2014 | 01:41 PM
Kammy1's Avatar
Kammy1
Sorted guys, thank you for all your help. Live and clicking now.
Kammy
JoeyBoyden
Jan 4, 2024 02:36 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Red_bull
Aug 9, 2015 08:34 AM
