Temperature problem
Old Feb 16, 2012 | 03:32 PM
danme1987's Avatar
danme1987
Default Temperature problem
My temp gauge doesnt go to tha half way point more like a 3rd across. I ignored this and just thought must be ok. I
I also noticed my oil temperature doesnt go up. Prob and mm or 2 of movement from the bottom. I ignored this until yesterday when they both went to the halfway point on the way home.
The next day they were back down to the usual positions.
Any idea what could be causing this?
This is on a ST170
cheers
Old Feb 16, 2012 | 08:08 PM
RichieST's Avatar
RichieST
Sticking thermostat. Get a genuine one from Ford, only a few quid, and takes less than 5 minutes to change!
Old Feb 16, 2012 | 10:42 PM
danme1987's Avatar
danme1987
would this stop my fans kicking in aswell?
Old Feb 17, 2012 | 07:23 AM
Fordmad!'s Avatar
Fordmad!
Yeah would cause problems with the fans aswell!
Old Feb 17, 2012 | 08:09 AM
oldford's Avatar
oldford
When the temperature stays cold, there's no reason to start the fans.
When you let the car idle at the end of a journey, does it get warm/hot then?
Do the fans kick in?
It does sound like a sticking thermostat.
Old Feb 17, 2012 | 02:19 PM
martysmartie's Avatar
martysmartie
As said it's a faulty stat (stuck open).
Martin
Old Feb 17, 2012 | 09:19 PM
danme1987's Avatar
danme1987
ok well ive changed it today. ill update with what happens
Old Feb 18, 2012 | 01:00 PM
danme1987's Avatar
danme1987
One day on and temp goes to half way as does the oil. Not heard fans yet though but not took the time to check.
Old Feb 18, 2012 | 02:03 PM
wrighty74's Avatar
wrighty74
Exactly same symptons as mine,new thermostat needed fella
Old Feb 20, 2012 | 06:14 PM
discos7u's Avatar
discos7u
Got the same problem on mine.
Is it really only a 5min job?
Could you pls give me a quick run down of the procedure or point me in the right direction?
Much appreciated...
Old Feb 20, 2012 | 06:26 PM
martysmartie
It depends on the model but it shoulden't be to tricky?
Basically drain cooling system, remove alternator, remove top hose from stat housing, remove housing, replace stat. Reverse this and replenish coolant.
As I say it depends on the model you have.
Martin
Old Feb 20, 2012 | 06:49 PM
RichieST's Avatar
RichieST
No need to drain coolant or remove alternator....
Follow top radiator hose to the thermostat housing where you will see 3 of 4 torx screws holding the thermostat cover on. Undo these, pop out the thermostat and put the new one in. Re-fit the cover, job jobbed. You'll loose about a litre of coolant so refill the level as required.
Old Feb 21, 2012 | 11:33 AM
discos7u's Avatar
discos7u
Thanks for the replies
I like the sound of Richie's method better!
But should have mentioned model - its an ST170
Same procedure?
It has 2 small hoses on the "alternator side" of the engine/rad and a larger one on the "airbox side" - presume I need to follow the larger one on the airbox side?
Old Feb 21, 2012 | 12:32 PM
martysmartie
In my defense that is the Haynes procedure
Follow Richie, as he obviously has been there and done it.
Martin
Old Feb 21, 2012 | 05:01 PM
wrighty74's Avatar
wrighty74
Spot on,changed mine yesterday,took no time,temp sits perfect at half way now
Old Feb 23, 2012 | 11:47 PM
danme1987's Avatar
danme1987
Ive changed my thermostat now and its perfect. thanks guys
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
