ST170 Help
Old Oct 31, 2011 | 09:35 PM
adsst's Avatar
adsst
Default ST170 Help
Hi i'm new here. I have owned my 52 plate ST170 for 8 months and for most of that time it has had an annoying stutter. This happens mainly between 30-40mph in 3rd or 4th gear. The car dosent run as smooth as id like but when you go through the revs its fine and revs freely.
The stutter isnt like a miss fire. Its more like the engine holds back on and off for a couple of seconds. There are no fault codes but its been plugged into a snap-on diagnostic machine which shows the e-vac isnt working propely but i have already changed this and checked the vacume and other pipes coming from that and all seems fine.
Hope someone can help as my patience is really running out of patience and would like to sort it before i sell it in the next couple of weeks.
Adam
Old Oct 31, 2011 | 10:18 PM
adsst's Avatar
adsst
Right i have just done a few searches on the forum and threads come up with very similar problems. What is this common stutter (map problem) the st170's have?
Adam
Old Nov 1, 2011 | 02:30 PM
Sp3no's Avatar
Sp3no
There is a flutter at low rpm between 2000-2200, it almost feels like your driving into a strong wind and the car is holding back but at soon as you get through it the engine should rev freely. If your having issues throughout the rev range i would start to look at either the coil pack or fuel pump starting to fail
Old Nov 1, 2011 | 05:50 PM
adsst's Avatar
adsst
Thats it. It happens when i am just pootling around town and cruising at 2-3k rpm.
Thanks for your help.
Adam
Old Nov 2, 2011 | 02:13 PM
Sp3no's Avatar
Sp3no
Sounds perfectly normal, a "decent" remap will get rid of it
Old Nov 6, 2011 | 01:26 AM
voo2doo's Avatar
voo2doo
I have the same problem @ 2400rpm,its down to the ecu.
J
Old Nov 6, 2011 | 11:57 AM
g_davison's Avatar
g_davison
does every st170 have this problem then? i must admit its f***ing annoying. re-map it is
Old Nov 6, 2011 | 01:18 PM
Sp3no's Avatar
Sp3no
Yes they all have it, its not the ECU itself but the engine map, they all have the same map so have the same stutter
Old Nov 6, 2011 | 09:13 PM
voo2doo's Avatar
voo2doo
Wheres the best place for a map fellas?
J
Old Nov 10, 2011 | 01:31 PM
adsst's Avatar
adsst
Im glad its normal. I am putting the car up for sale so its a relief to know its nothing major. How muh would you guys suggest putting it up for.... Its 52 plate, blue, 29000 miles, good condition, only minor stone chips, FSH????
Adam
Old Nov 14, 2011 | 12:46 PM
Sp3no's Avatar
Sp3no
Ł3250 i would say and hope for Ł3000 they are so shite on fuel no one wants them
Old Nov 15, 2011 | 09:22 AM
adsst's Avatar
adsst
I know what you mean about the fuel...not good around town. Better on the motorway runs!
Old Oct 18, 2012 | 09:25 PM
huddo's Avatar
huddo
Just having a dig around the site and came across this post, looks/feels like my recent 04 plate purchase had the 2000ish rpm stutter. How come Ford never came up with a fix for this problem if all ST170s have this problem ?
Old Nov 3, 2012 | 03:40 PM
melinamotor's Avatar
melinamotor
Farpylee
I owned a 170, very dissappointed with the car, a fuel filter change helped a little but it drank the stuff when you tried to eek out what little performance you had. Gearbox is a joke too. I prefered the raft of standard Mk1s ive owned over the years. The RS is definately the Mk1 to go for.
Old Nov 3, 2012 | 04:43 PM
daviddunlop83's Avatar
daviddunlop83
My ST170 was the same when bluefin wasnt installed.
Buy a bluefin or a remap and it should be fine
Old Nov 5, 2012 | 01:06 PM
borinous's Avatar
borinous
Mine has this...just need to get funds together for a bluefin or remap
Old Nov 5, 2012 | 10:02 PM
huddo's Avatar
huddo
Bluefin currently 20% off til Christmas !
Old Nov 6, 2012 | 09:02 AM
RS2000CUSTOM's Avatar
RS2000CUSTOM
You need to "live data read" your Lambda probe
Had exactly same problem
Tried plugs, coil pack, leads etc - still "stuttered"
Replaced Lambda and now perfect and big improvement in fuel consumption
Old Nov 6, 2012 | 06:35 PM
borinous's Avatar
borinous
Good shout...I keep getting a 0420 error code which I believe is related to the lambdas so I'm planning on changing them soon anyway.
Anyone know where the best place to buy them from? Direct from ford I presume?
Old Nov 7, 2012 | 06:09 PM
RS2000CUSTOM
I had no codes present or EML light on
My Snap-On Solus ultra was able to "live read" the engine sensors etc
What I found was the Lambda gave a flatline constant reading regardless of revs, load, emmissions etc etc BUT because it was inbetween the minimum and maximum permitted parameters the ECU did not register a fault and therfore did not store a code or put a warning lamp on.
After replacing the lambda the "live reading" gave a "peak and trough" reading that altered with the engine load, speed, throttle position etc
As said before all is now perfect and better fuel consumption
Have found this on http://www.sparkplugs.co.uk/pages/pr...Sensor-ccp.asp
Front Sensor
Part Number
Stock Code
Price (Ł) Each
Buy
OZA488-D2
1757
49.5+vat
Rear Sensor
Part Number
Stock Code
Price (Ł) Each
Buy
OZA381-D3
0462
49.5+vat
Old Nov 7, 2012 | 08:48 PM
borinous's Avatar
borinous
Haven't got the ability to live feed. Is there any software available to use with a laptop? Currently only have a basic obd reader.
But i see what your saying.
They aren't badly priced but isn't the preferred replacement bosch?
Old Nov 7, 2012 | 10:32 PM
RS2000CUSTOM
I didnt get mine from there but it was an NGK unit I used and has been fine for the last 4 months
Old Nov 8, 2012 | 06:09 AM
borinous's Avatar
borinous
Cool cheers good to know. And you replaced both at the same time?
Old Nov 8, 2012 | 08:15 AM
RS2000CUSTOM
No need to replace both as only the one was "flatlining"
I replaced Sensor 1 Bank 1 Upstream - the one nearest the engine
Old Nov 8, 2012 | 11:52 AM
borinous's Avatar
borinous
Makes sense. Cheers
Old Nov 8, 2012 | 04:10 PM
JOHNDQ's Avatar
JOHNDQ
Have you checked there isnt a software update from Ford, i know when we have replaced the IMRC ECU's at work Ford said they need a ECM update which we have always done and never had any come-backs etc
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
