code P1383, ST170
Old Jun 14, 2011 | 07:22 PM
bampson's Avatar
bampson
Default code P1383, ST170
following on from my previous post "Rough running when hot" , i had the car on a mates scanner and it cam up with the code :
P1383 Variable CAM Timing Over Retarded (bank 1)
Any one have any idea what this is all about ?
i am at my wits end with this , if i cant find a cure i might just end up Breaking the car for parts ..
Any Help would be appreciated...
Old Jun 14, 2011 | 07:47 PM
RichieST's Avatar
RichieST
Pull out the airbox (it pulls upwards, might be stiff though), then underneath on the side of the inlet manifold is a plastic lever with a cable attached to it. Make sure it is still connected and it pulls round 90 degrees when you start the engine.
Old Jun 14, 2011 | 09:43 PM
bampson's Avatar
bampson
Thanks , i will give it a go tomorrow and report back .
Old Jun 15, 2011 | 04:11 PM
Sp3no's Avatar
Sp3no
That fault is normally thrown up when you change the cam belt inccorectly without loosening off the cam pullies, when was the cam belt last done. Could also be the sensor playing up obviously, the sensor is under the plug cover on the left hand side of the cam cover near the inlet pully
Old Jun 16, 2011 | 02:47 PM
bampson's Avatar
bampson
I have tested this and the cable is connected and it does move about 90 degrees on start up.
any other ideas ? thanks
this could be the case as the belt was done recently and i have changed the cam sensor.
Is there any way to tell for certain that this is the case ?
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
