ST170 Runs Rough when hot
Old May 13, 2011 | 10:44 PM
bampson's Avatar
bampson
Default ST170 Runs Rough when hot
Hi, I have a 52plate ST170 which runs fine when cold but once the temp goes up to normal it starts to run rough .
the rough running is really bad, to get it to go you have to rev then back off of the accelerator then it will go slowly ..
i have changed lamba sensors checked for air leaks , new plugs and HT leads , havent changed the coil pack as i don't want to spend the money unless i am sure its faulty .
Any ideas ??
thanks
Bamp
Old May 15, 2011 | 11:03 PM
Sp3no's Avatar
Sp3no
Coil pack, then fuel pump
Old May 20, 2011 | 07:56 PM
When was fuel filter last changed ?
Old May 27, 2011 | 03:49 PM
bampson's Avatar
bampson
turns out it was the cam shaft sensor ..
thanks guys
Old May 30, 2011 | 05:19 PM
c14aff's Avatar
c14aff
Mine runs lumpy at idle but clears when rev's are raised, how did they find the sensor problem?
Old May 31, 2011 | 06:01 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Try what i said cuz , if that dont work then we can look at something else
Old May 31, 2011 | 01:11 PM
c14aff's Avatar
c14aff
Laptop says "Running lean" Lambda sensor one!
Old Jun 6, 2011 | 06:28 PM
bampson's Avatar
bampson
And my problem has returned , cam sensor seemed to fix it for a bout a week now the problem is back.
Is there away of testing the Fuel pump?
Main stealer wants roughly £250 so i would like to be sure before i fork out all that wonga ,,
thanks
Old Jun 7, 2011 | 06:14 AM
chaffe's Avatar
chaffe
Any ideas ??
thanks
Bamp
the fact it runs fine when cold suggests the pump is in GWO, very uncommon for a fuel pump failure.
Old Jun 7, 2011 | 09:11 AM
white2lsr's Avatar
white2lsr
Sounds the same as the problem I had. It was diagnosed as the fuel pulp control module under the rear west carpet on drivers side.
Old Jun 7, 2011 | 09:48 AM
chaffe's Avatar
chaffe
because this system uses the pump as a fuel pressure regulator and has no return pipe, correct?
Old Jun 7, 2011 | 10:12 AM
white2lsr's Avatar
white2lsr
Correct
Old Jun 8, 2011 | 08:29 PM
bampson's Avatar
bampson
do you have any other suggestions ? i have run out of ideas and money .... i wil try almost anything now ..
Old Jun 30, 2014 | 08:18 PM
kevchard's Avatar
kevchard
Hi
Not much help after all this time i know, but mine ran like a bag of knackers when hot or cold.
After putting new cheapo MAF sensor off ebay on the ST, problem was still there. After lots of substituting other bits it turned out to be cheapo MAF sensor at fault. Full price £130 jobbie sorted problem a treat.
Kevin
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Rsmat
63
Sep 25, 2015 12:11 PM
xrmalin
Sep 13, 2015 06:52 PM
StephTell
Sep 2, 2015 06:31 PM
