st170 running problem
Old Mar 25, 2011 | 04:55 PM
bullsrs's Avatar
bullsrs
Default st170 running problem
Hi all, coming to work yesterday my car started misfiring,i parked it up and checked for dtc code on dash and none were listed, on my way home it was fine for approx 4mile then it started misfiring again, and the eml started to flash, when i got home i checked the dash for dtc code and it showed d073 (something to do with the cooling system) so i removed the connector from the thermostat housing and the car ran down the road with out any sort of misfire ( i had a similar prob with my escort si and the temp sensor was the problem), although, as i expected, the gauge wasn`t working and the fans cut in autiomatically, i have just changed the temp sensor incase it is that but havent had time to try it out as i`m still at work, but have had time to start the car and unfortunately the eml light is still on, do i need to get this reset at ford or does this mean the problem remains, any ideas on the light or other reasons for the misfire welcome, i`ve had the car since 12th sept 2010, it has full history and i did a full service on it myself three weeks after i got the car, including new frod spark plugs, i should say when the car is cold it was running fine til the engine warmed up, cheers,roy
Old Mar 25, 2011 | 08:55 PM
bullsrs's Avatar
bullsrs
ran fine coming home with new sensor, still got light on though
Old Mar 25, 2011 | 08:59 PM
Sp3no's Avatar
Sp3no
Disconnect battery for 30mins this will clear code. You cant actually properly read dtc codes from the dash you need a code reader.
Old Mar 25, 2011 | 09:10 PM
bullsrs's Avatar
bullsrs
thanks for that mate, been reading some other posts on here and notice you changed the clutch on yours, did you keep the dmf or fit solid flywheel, central florida motorsport seem to have some decent kit at decent prices, doubt the import tax will be decent though
Old Mar 25, 2011 | 10:23 PM
Sp3no's Avatar
Sp3no
I have a clutch masters stage 3 aluminium fly and kevlar clutch from cfm. Cost 90 in import tax but all in was still cheaper than a dmf and clutch from ford.
Old Mar 26, 2011 | 01:28 PM
bullsrs's Avatar
bullsrs
Unhappy
well misfire still remains, i drove it around today for 20mins with not a hint then went out in it 20 mins ago to pick kids up from dancing after 2mins driving it was popping + misfiring again, grrr
Old Mar 26, 2011 | 01:34 PM
Sp3no's Avatar
Sp3no
Coilpack next, they are not too expensive brand new from ford.
Old Mar 26, 2011 | 01:43 PM
bullsrs's Avatar
bullsrs
think i have a good spare somewhere, just read here on p11 that the fuel pump seems quite unreliable, and when i changed my fuel filter last year the fuel was dirtier than what come out of the one on p11, anyway off to my mates in 20 mins to use his code reader happy bloody days lol
Old Mar 26, 2011 | 04:39 PM
bullsrs's Avatar
bullsrs
fault code reader found 2 codes 1st was p0118 water temp sensor and 2nd was p0303 3rd plug lead, gotta wait til the mrs finishes work to look after kids so i can rummage in my shed and garage for the spare leads i had
Palethorpe01
15
Aug 18, 2015 06:09 AM
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
Zoggon
Aug 10, 2015 10:39 AM
