st170 fault codes
Old Dec 13, 2010 | 04:57 PM
scortpower's Avatar
scortpower
Default st170 fault codes
right i am pretty sure i am thinking right but i hit a speed bump bit faster than i should of done and got a right thump from underneath due to the car being so low. anyway ten mins later when i had turned the car off and restarted the engine light came on. with these codes. p0135 p0131 and p1131 all relating to the front lambda sensor. think thats a good indication the sensor is fooked! Agree??
Old Dec 13, 2010 | 05:05 PM
phil_focus's Avatar
phil_focus
yep i'd say you've fucked it.
i'd also check for other damage like cracked exhaust, sump, etc from hitting the deck and check your tyres if they like to occasionaly catch the little tab on the wings.
Old Dec 13, 2010 | 05:12 PM
scortpower's Avatar
scortpower
everything is fine checked all that were just unsure on the sensor as it looks ok!?. the car is that stiff its never catched the tab on the inner arch plus the tab has been bent up to avoid it lol
Old Dec 13, 2010 | 06:24 PM
phil_focus's Avatar
phil_focus
damn thats stiff, what suspension has it got and what spring rates??
mines still on standard suspension and i'm running 205/55/16 for daily instead of 205/50/16 and with a full car n my rough roads it wuld catch the tab so bent the fucker up...a LOT
maybe its become unplugged??
or its tugged the wires and broke inside.
Old Dec 14, 2010 | 05:58 AM
scortpower's Avatar
scortpower
Have got Gaz coilovers on it running 205/45/17 off the top my head
checked its plugged in. am guessing its broke something inside for all 3 codes to appear.
Old Dec 14, 2010 | 11:20 AM
phil_focus's Avatar
phil_focus
did you order any specific spring rates with the gaz as i'm very tempted to get them (not the golds) or did they come with a generic set of springs?
yeah for all 3 codes it must be duff inside. would have thought thered be some obvious external damage aswell though.
Old Dec 14, 2010 | 12:08 PM
scortpower's Avatar
scortpower
couldnt tell you about spring rates i bought the focus with them on they are gaz golds. there prob is some damage i havent taken it off yet just had a look from the engine and it looked ok but will prob have a bang on it as its close to the sump where the decat locates the lambda
Old Dec 21, 2010 | 04:55 PM
scortpower's Avatar
scortpower
Right sorted the problem bought a new lambda and it cured it. Noticed the old one had a small dint in it from where it hit sump. All fixed anyway
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Si B
Sep 12, 2015 06:49 AM
